Hot Rods Model a coupe grille height
Discussion in 'The Hokey Ass Message Board' started by pompadour, Jan 8, 2009.
  1. pompadour
    pompadour
    i have been looking at alot of posts about grille height...i have seen lower than the cowl and higher and level...i think i have it right just above the cowl...
  2. SlamCouver
    SlamCouver
    from Brazil, IL
    Level with cowl is the way to go. then when you run a hood the slope doesnt look so goofy.
  3. Taller than the cowl looks like ****, doesnt flow. Too low and it gets odd like Milners coupe.
    Level or slightly lower or at least so the eye "thinks" its lower.
    I would not mess with **** until you get the proper sized rollers or the tires you plan on running to get ride height dialed in.
  4. Dirty Dug
    Dirty Dug
    What looks best and most resembles the car's original lines is to have the top of the grill shell line up with a line down the slope of the cowl.
  5. JRRoberts
    JRRoberts
    from Madison WI
    I vote mount it level!
  6. chaddilac
    chaddilac
    second.... all in favor.... I!
  7. pompadour
    pompadour
    grilles up down and level
  8. 31modelo
    31modelo
    Level unless you paint it yellow and slap a Man a Fre on it.
  9. Lazy White Boy
    Lazy White Boy
    Level to just a tiny bit lower, follow the natural lines of the car, please do not go higher.
  10. Live Wire and the black coupe WOULD look better with a lower shell. Camera angle do make em look better or worse.......both car are nice regarless.
  11. rick finch
    rick finch
    Level or slightly lower! Do not mount it higher, car will look like it is going up hill otherwise.
  12. roadduster54
    roadduster54
  13. HotRod33
    HotRod33
    I level
  14. jmon77
    jmon77
    from Tennessee
    I think the chop has some to do with the profile from front to back. Chopped should deifinately be level or lower. Non chopped could maybe get away with a little up, but I would definately recommend at least level. I went level without a chop. The only thing to watch for is if you are gonna run radiator supports they will run uphill unless modified.
  15. cretin
    cretin
    personally I think it looks like **** when its higher. I like it to sit so that if you put a hood on it everything would fit right. Just like some others have said, level or slightly lower.
  16. Comet
    Comet
    When you mock it up, use masking tape from the cowl to the grill shell and step back and look at the lines. It should have a slight natural slope towards the grill shell.
  17. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    The car i was building.
  18. Donut Dave
    Donut Dave
    I dropped the stock grill shell 3/4", if you keep it stock height it can look like it's running up hill from some angles. Just my $ .02 worth
