Model A Coupe value?
Discussion in 'The Hokey Ass Message Board' started by ty johnson, Dec 18, 2013.
  1. ty johnson
    ty johnson
    I'm looking at buying another Coupe project. It has usual midwest rust in the lower qtrs, doors are solid and cowl has a lil rust. It has a deck lid that's useable. Comes with a frame also. And it has a ***le. It is a project for sure though.
    Thanks,
    Ty
  2. go-twichy
    go-twichy
    does it still have its fenders , hood, gl***, engine/ trans, splash aprons, bumpers, seat,etc? kinda tough without more info or better yet, pictures! 28-29, 30-31?
  3. ty johnson
    ty johnson
  4. brandon
    brandon
    rear fenders are sedans...guessing they are wanting around 3500:D
  5. 56shoebox
    56shoebox
  6. aerocolor
    aerocolor
    from dayton
    ***les bring that around here....
  7. jkski
    jkski
    $1000 to $1500 if it's a good mo.***le.yep,those are not coupe rear fenders.
  8. hellerlj
    hellerlj
    from Minnesota
    Here in the Minneapolis area, that would go for at least $3000 and maybe more,
    Coupes seem to be the "HOT THING" now, so I find, if you want one, buy it when
    you find it, if not, there will be someone close behind that will....OH YA, ***le in
    itself is worth minimum of $500....can be a huge help down the road, but I am sure
    you already know that...Good Luck
  9. alchemy
    alchemy
    28 body with 30 fenders and hood. And they conveniently covered up the rust-prone spots with the splash aprons.
    We need BETTER pictures.
    From that pic I'd think a thou$and would be safe. May be worth more if you can prove it's better condition.
  10. kb cookout
    kb cookout
    The hood, cowl and doors are 1930-31, the rear 1/4 panels and roof is a 1928-29
    I would check the doors to make sure they are coupe and not sedan / pickup doors.
    you could part it out easy for $2500- $3500
    later kb
  11. flatford39
    flatford39
    Alchemy nailed it.
  12. brandon
    brandon
    4dr cowl...?
  13. cayager
    cayager
    saw that on ebay for $2700. had it saved in watch list. located in troy, MO.ended this morning at 8;15 did you get it?
  14. alchemy
    alchemy
    Oops. After further viewing of the excellent pic, I too see that the cowl and doors are for a 30/31. Looks like the only 28 parts are the rear quarters.
    This is just a bunch of mismatched parts that are good for nothing but parting out. Save your money.
  15. adam401
    adam401
    Personally I wouldn't want to start with something that ****ty for s model a for what it probably cost. That's alot of stuff in those pics but it's mix matched stuff from ten cars. For a little more hunting and a little more cash you may end up with a complete but rough car or a decent coupe body. model a isn't rare enough for me to start with that stuff unless its a smoking deal. Pay a little more, get way more.
  16. mike bowling
    mike bowling
    I'd agree with the $1000. to $1500. price range. Looks like someone stuck a bunch of leftovers together.All worth something, but probably not to the same person. Looks like about $10. worth of zip-ties?? Coupe bodies I've seen that are worth looking into are running$2000. to $5000. ( yup, for a Model A) Good luck. Mike from M***.
  17. Does the number on the ***le match the number on the frame?
    Charlie Stephens
  18. scrap metal 48
    scrap metal 48
    The 28/29 quarter window openings are 1" taller than the 30/31 door window openings meaning the back half doesn't match the front half...
  19. 31Apickup
    31Apickup
    Doors look to be 30-31 Tudor/pickup, I can't see the circular depression for the window cranks on the inside that only Coupe doors have.
  20. go-twichy
    go-twichy
    if you didn't get it, i wouldn't feel bad.
  21. jackalope
    jackalope
    If you bought it and opt to part out I need a ***le:cool: Shhhhhhh:D
    --Anonymous
  22. ty johnson
    ty johnson
    I offered $1500 and got turned down so i'm out. I had him send me those pics and got to noticing all the mismatched parts. I'd like to have from the rear back though.
