Model A Cowl Steering - My Way
Discussion in 'The Hokey Ass Message Board' started by Harrison, Jul 6, 2004.
  1. Harrison
    Harrison
    Take me off the list of guys asking how it's done and put me on the list of guys who have done it.
    Special thanks to Jet Fuel for turning me on to the BMW box and sending pics of his installation and to Clark for posting numerous pics and answering questions about his set up. Thanks also go to Ratster who gave me the '40 column.
    The box is a '68-'76 BMW ZF unit. It is about 6 turns lock to lock. For my installation if was just long enough to center the wheel in the gauge cluster while also making it out the side of the cowl without further modification.
    Braces from side to side were made with 1" tubing and the box hangs from that. I have a couple inches of room between the pedals and box.
    I did have to break down and buy a Borgeson U-joint to make it all happen. I'll lengthen my column under the dash to run all the way down to the U-joint before I finish the car.
    For me this is another "big project" out of the way. The engine comes back from the builder this week and I'm hoping to have the ch***is painted by the end of the month.
    I'm slow - but I'm working.
    JH
    29EHV8 likes this.
  2. Harrison
    Harrison
  3. Harrison
    Harrison
  4. slammed
    slammed
    Great information. Sharing it too. On topic, usefull tech. The model A sedan is going to be my next and last ride. Trad./Rat style. Time to thin the herd.....car wise. Keep posting your update's,please.
  5. FoMoCo_MoFo
    FoMoCo_MoFo
    NICE WORK!
    expect many PM's from me regarding this
  6. Detonator
    Detonator
    from santa cruz
    You may want to tie your platform to the firewall, too, there's a bit of play in that A cowl. Plus make sure your firewall is good and stiff. The platform will serve as a gusset between the firewall and cowl sides and stiffen everything up. Just my 2¢.
  7. Looks Very Nice!
  8. ray
    ray
    from colorado
    nice work, but i would really not trust that A cowl to handle all of your steering forces, as a minimum it'll wrack your body, at worst it will rip out killing you.
    but then what do i know.
  9. Levis Classic
    Levis Classic
    I would agree with ray, Tie her into the floor sub frame or the frame and your good to go!
    29EHV8 likes this.
  10. Looks like that steering box works great. Is that the stock pitman arm? Can I see a better pic of it? It has a nice look to it.
    Even if tying the brace that holds the steering box to the subfloor is overkill. It's better to be safe than sorry.
    Clark
  11. If you are tied into the subrail, you still arent welding to anything more than 10 or 12? Gauge!I contend that the loads are more perpendicular to the longitudinal axis of the car, ie: twisting the box from right to left. I dunno, mine is simlar with a little more beef.
  12. 34Fordtk
    34Fordtk
    That looks like a clean box to use,but I go along with everyone also you need to tie into the frame/ch***is as strongly as you can. My box on my truck would twist the stock frame if you tried to turn it while stopped.
  13. rjb
    rjb
    from ICT KS
    That looks great!! I'm wanting to do a cowl steering set up on my '27 T coupe project. I have always liked the way they look.
  14. Harrison
    Harrison
    I was thinking along the same lines as Tman when I built it. Still, it looks like tying it to the forward body mount holes and the firewall would be fairly easy.
    I'll get the engine in it and see how bad it wiggles with a little weight up front.
    Clark, the pitman arm is stock. My camera is a POS up close (these pics are about as close as I dare get with it). I'll do some looking on Ebay to see if I can find a better close up pic.
    Thanks, Jim
  15. Harrison
    Harrison
    Here you go Clark.
  16. heyitsnate
    heyitsnate
    harrison,i think you're doing some really nice work.it's good to see some original tech....i'll post pics of my cowl steering experiment soon....it'll be good for a laugh or two!
  17. Nice work, Harrison! If I don't get a move on, you'll be done looooong before me! [​IMG] AntiC is comin down, this weekend, so maybe we'll make a little progress. Maybe.
  18. Jet Fuel
    Jet Fuel
    from SoCal, USA
    Bad ***. Nice to have the steering paradox somewhat behind you.
    Harrison and I have already spoken about it, but I thought it should be mentioned here that a GM A-Body (and likely others) pittman arms will work too 'cause they have the same spline. You'll likely want to mill out the indexing splines so you can put it on in the orientation that fits your application. You might have to open up the taper for the tie rod end. ...but the spline pitch and taper are the same.
    As far as flexing and all that, mine wanted to push the box front and back versus twist. It's just one of those things you've gotta play around with to see what it wants from you. It'll tell you what changes you need to make once you get weight on it.
    Cheers, Harrison. Nice work.
    -jf
  19. Harrison,it looks good.Added bracing=added bonus.
    I gotta look for one of these boxes for my lil rpu project.
    Thanx for the tech post......Shiny
  20. theodore
    theodore
    Hey Shiny, talk to Rick at CB autotech, they always have a BMW in there that's written off, might be able to scoop a decent one.
    29EHV8 likes this.
  21. zibo
    zibo
    from dago ca
    <font color="blue"> you will need that bracing. the twisting force is strong enough to open your doors, unless you are making a coupe or sedan. The other thing that ****s about cowl steer is it leans your car the wrong way around turns. </font> TP aka zibo
  22. silent rick
    silent rick
    wow, your ride really looks exactly like this ratrod for sale in the cl***ifieds. almost.
    sorry, sometimes i can't help myself. [​IMG] [​IMG] [​IMG] that's a nice looking box. it rotates the correct way? 68-76 bmw, are those the only years? and what models were they used on?
    i'm saving all these cowl steering tech posts. thanks for posting.
  23. bradberry00
    bradberry00
    why is it that when i go to that steering wholesale site they say they dont carry that bmw box????
    I wanted to check out the price of that baby....
  24. Harrison
    Harrison
    It turns the right way to work. It came on a 2002 series BMW. Go to Ebay or the junkyard. $50 will buy a good used one. A remanufactured unit will run $230 or up.
    JH
  25. ratster
    ratster
    looks good Jim! , glad the steering column worked out for you and the price was right haha
  26. Jet Fuel
    Jet Fuel
    from SoCal, USA
    [ QUOTE ]
    [/ QUOTE ]
    Yep, they rotate the right way. BMW put the steering gear behind the spindles.
    They come on all BMW's between 67 and 76. Before that they didn't make full size cars. After that, they finally started using a rack.
    These are available all over ebay for 5-15 bucks from private parties and for 50 bucks from 2002AD. If you're around the Antelope Valley area of California, you can go to AD yourself and have your pick of the litter. They've got pallets full of 'em.
    -jf
  27. John boy
    John boy
    We are planning to run the bmw steering box on the 27T we are building. Could you tell us which borgeson universal joint (part number#) you selected to match up with the splines on the bmw box. Thanks John Boy
  28. Bonehead II
    Bonehead II
    Thats a boy Johnny, You got there before I did.
    Mike
  29. Good outside the box thinking.
    I've thought for a long while that some of the foreign car boxes would be a good candidate for hot rods.
    I'm with the other guys as well, a little more bracing please.
    Six turns lock to lock?
    That seems exceptionally slow.
    My 32 with Vega box is just short of 4 1/2 turns lock to lock with the proper stop nuts installed.
    It seems kinda slow sometimes, but I'm probably comparing it to the 2 1/2 or so turns in my 88 Mustang . . . course it had power ***ist, but the fast steering and minimal power ***ist worked out well.
    It looks too like the Beemer box was originally used in a cross-steer configuration and mounted on top of the frame.
    Interesting that the GM A body pitmans will fit.
    There's a few different shapes of those that would work well in a cross-steer installation.
    Regardless, cowl steering is about as cool as it gets.
  30. fab32
    fab32
    It's amazing how many cars use the same size spline and spline count. Saginaw steeringgear Division of General motors has built steering gears for virtually every auto manufacturer in the world. They long ago figuered out strength/ size/ weight issues and sold their products world wide. The steering division is about 25 miles from where I live and it's been in 24 hr/day 7 day a week operaton for all of the 40 plus years I've lived here.
    Frank
