Hot Rods Model A diff oil.
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, May 6, 2022.
  1. panhead_pete
    panhead_pete
  2. wheeltramp brian
    wheeltramp brian
    I personally use a half quart of Lucas Oil stabilizer and top it off with 85-1 40 oil and haven't had any problems even in the stock a gearbox. This is in my mildly hopped-up Model A Cabriolet with stock running gear
    panhead_pete likes this.
  3. Gastrap
    Gastrap
    I've had good luck with 85-140 in rear and trans.
    gimpyshotrods likes this.
  4. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Modern oils will work well. You can get the "clinging" effect by mixing 85-140 oil with STP or similar (Lucas oil stabilizer?). If using modern oil it is a good idea to leave the oil level 3/4" below the bottom of the fill plug hole to help prevent seal leakage problems. Some of the 600 weight oil sold by the Model A parts vendors appears to my calibrated eye balls to be nothing but 140 wt. Snyders Antique Auto Parts is probably the best bet for the good stuff.
  5. Hotrodmyk
    Hotrodmyk
    Regular 85w-140 gear lube work just fine in stockers.
  6. gimpyshotrods
    gimpyshotrods
    Same.
  7. gimpyshotrods
    gimpyshotrods
    600W and 85W-140 are two oils rated on different scales.
    One is ISO steam cylinder rating, and the other is SAE lubricant.
    The Viscosity Index, ASTM D 2270 of 600W is: 95.
    The Viscosity Index, ASTM D 2270 of 85w-140 is: 97.
    The use of 600W as a gear lubricant in an vehicle is obsolete.
    My oldest service manuals go back to 1937. By then, there is no mention of 600W in any context. Ford had switched over to SAE gear oils.
  8. panhead_pete
    panhead_pete
    Cheers all. Got oil arriving tomorrow :)
