Hot Rods Model A distributor suggestions
Discussion in 'The Hokey Ass Message Board' started by Koz, Mar 30, 2024.
  1. Koz
    Koz
    Not a lot of experience with bangers. What would be a good newer distributor for an A-bone? Prefer something with either centrifugal advance or a vacuum that would work on an A. Not much for the little lever stuff. This is an off road TROG / dirt track race car. No street use.
    Thanks guys!
  2. woodiewagon46
    woodiewagon46
    from New York
    Braton's Antique Auto Part's, www.brattons.com has an Electronic Centrifugal Advance Distributor for Model A's PN 17080, 6V. and PN 17090 for 12V. not cheap about $350 last time I looked.
  3. don colaps
    don colaps
    Cheap is slightly modified bosch distributor from a Volvo B18 or B20
    winduptoy likes this.
  4. GZ
    GZ
    from Detroit
    This is the distributor that I would recommend. These are completely new, complete and will drop right in and you are ready to go. They are very reasonable priced. They have modern capacitor and points. You can use the "crab" original style body/cap and the flat connectors or the "normal" style cap that takes normal plug wires. This is a manual distributor, which I would recommend.
    Yes, you can find an original Mallory, etc. and they work. However, a Mallory is expensive if you can find one and they are harder to work on, expensive, and difficult to find parts.
    These are available from Snyder's.
    Snyders - Product DISTRIBUTOR A-12100-MX (snydersantiqueauto.com)
  5. dwollam
    dwollam
    I run an automatic advance Model B dist in my '31 coupe with a Model B engine. In my '31 Roadster pickup I run a stock Model A with modern points plate from Snyders. Both work fine and both cars are used differently.
    Dave
  6. winduptoy
    winduptoy
    Call Shaun at FSI in Ponca City, OK
    https://www.fsignitions.com/
    He will set up the spark curve for your application
    or I have A and B dizzies that I have gone thru...and even an FSI that Shaun went thru recently when I paid him a visit
    Zax and firstinsteele like this.
