Does anyone know if the door on a 30 Model A Sport Coupe is the same as a sedan door or a coupe door? OR could someone measure the length and height on their sedan and /or coupe doors? Thanks I won't door you anymore.......
30/31 coupe doors are all the same regardless of model. They differ from Tudors and pickups as the coupe doors are shorter in length. Just as an aside, for 28/29 all coupe and Tudor doors are the same length.
The doors on tudor sedans, closed cab pickups, and sedan deliveries are all interchangable and roughly 29" wide. I'm at work and my sedan is in the garage at home so I can't get the exact measurement. The coupe doors are around 27" wide. So if you have a door that's around 29" wide its only going to fit the 3 above mentioned vehicles.
sport coupe is the same as coupe 27ish inches wide, NOT the same as sedan, sedan is same as pick-up 29ish wide
That's what I was saying, sorry if it wasn't clear. All Standard, Deluxe and Sport coupe doors are the same for 30/31.
