model a doors
Discussion in 'The Hokey Ass Message Board' started by M1racer, Mar 19, 2009.
  1. M1racer
    M1racer
    from Montana
    any good ideas or better ways to seperate inner door pannels from outter door...........getting tired of drilling
  2. manyolcars
    manyolcars
    Dont most folks grind the edge til they separate?
  3. M1racer
    M1racer
    from Montana
    seamms there are spot welds every inch or so.....behind the lip
  4. Corn Fed
    Corn Fed
    Why are you wanting to remove the skin? Will you be reskinning it or just want access to hammer out dents? If the skin is junk and will be replaced, simply grind the outer edge until the lip is separate from the skin. You'll still need to grind some spot welds away.
    If you are just wanting to get to the skin for dent repair, just remove the the flat inner panel, leaving the vertical posts attached. The best way to do this is drill out all the spot welds. The not so good but easier method is to jig saw it along the edge.
