On a 1930 Model A, is it possible to remove the drive shaft from the banjo by removing the nut holding the pinion gear on the shaft and pressing the shaft out without removing any other parts such as nuts, keeper washer, etc.?
Jim, This is the intro page. You will get a much better response by introducing yourself first and then posting your question on the main message board. There is an extreme abundance of info at your finger tips if you follow the rules at the top of this page. Welcome from Michigan and good luck.
