Hot Rods Model a dropped axle has too much camber
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Jul 17, 2026.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    I bought a roadster a couple years ago that has been in the corner while I collected parts. It had a cheap Chinese dropped axle under it and I had bought an original dropped an axle to put under it. I put it in and it looks to have too much camber. Do I have mis matched spindles to this axle? Was it dropped wrong? Did I ***emble something wrong? IMG_9956.jpeg IMG_9955.jpeg IMG_9960.jpeg IMG_9958.jpeg IMG_9957.jpeg IMG_9959.jpeg
    Deutscher and Just Gary like this.
  2. Ned Ludd
    Ned Ludd
    Might the kingpin inclination have been altered to work with different spindles when the axle was dropped? E.g. '49-'54 Chevy spindles have a much smaller KPI angle, so if the axle was set up for those and you put Ford spindles on it, you'd get about the camber you've got.
    hotrodjack33 likes this.
  3. philosofriend
    philosofriend
    There is probably a shop not too far from you that does big truck frame repairs. They would have the tools and experience to adjust that axle.
    pprather likes this.
  4. flying53gmc
    flying53gmc
    from M-boro, TN
    I have a bunch of 49-51 Chevy cars and parts cars. What is the simplest fix if that’s correct? Changing to Chevy spindles might open another can of worms. Can this axle be tweaked enough to get the camber right?
    Ned Ludd likes this.
  5. 26 T Ford RPU
    26 T Ford RPU
    You need to check the scrub point, where the king pin centre line intersects the ground should be in the centre of the tire contact patch. It doesn't look that bad really. The angles all have to work together.
    My RPU looks very similar (both sides are the same) , the axle is so cal speed shop forged item with 48 spindles. JW
  6. BJR
    BJR
    Stupid question by me, could they be on upside down?
    26 T Ford RPU likes this.
  7. 26 T Ford RPU
    26 T Ford RPU
    That would produce less camber. JW
  8. hotrodA
    hotrodA
    Hi Neighbor!
    That is a pretty easy camber correction for any truck alignment shop with the right tooling,
    and experienced tech.
    Both Hunter and Beeline supply the kits, if the shop bought it with their rack.
    When I did that work, we took most of the positive camber out, leaving zero on the right,
    1/2* + on the left..
    302GMC, 26 T Ford RPU and lostone like this.
  9. Clydesdale
    Clydesdale
    Just a bit pick but an important detail before you speak to a shop about fixing it.
    You have too much POSITIVE camber, camber should be relayed in terms of positive (top of the wheel out) and negative (top of the wheel in)
  10. krylon32
    krylon32
    from Nebraska
    There is an axle dropper that has a history of excess camber drops. I've had a couple, corrected that in a press.
  11. anothercarguy
    anothercarguy
    With a bit of enginuity, tools and determination it can be fixed at home. I set this up to correct the issue on the dropped Ford axle in the '38 cabriolet.
  12. lostone
    lostone
    from kansas
    Yep find a good truck shop that has knowledgeable people and that would be a easy fix.
    winduptoy likes this.
  13. Yep, those things bend. Just need the right tool.
  14. leon bee
    leon bee
    At what point on the axle would force be applied? Would you try to bend right where it was stretched?
  15. hotrodA
    hotrodA
    No. If it’s 3.7* + on both sides, you would hold it down in the center, or between the spring perches equal distance.. A single hold down in the center may give it too much of a sharp bend,to be esthetically pleasing.
    That would be the fastest and cheapest in a shop, and take less push force.
    It COULD be corrected where it’s bent with the hold down between the perch and the bend, but it would be hard to push up the end. That might be better done in a press.
    @anothercarguy has it right with his hold down and pushing up on the bare axle end.
    Great setup!
    anothercarguy, leon bee and Budget36 like this.
  16. Relic Stew
    Relic Stew
    from Wisconsin
