Model A engine install with T5 transmission attached?
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Zener424, Jun 21, 2013.
  1. Zener424
    Zener424
    Hi folks, I am installing a rebuilt stock engine in my Model A and also changing the transmission from stock to a Chevy S10 Borg Warner T5. Can I install the engine with the T5 attached or is it best to install separately? I wasn't sure if there's enough clearance to do all at once, it seems like it may be too long as an ***embly. Thanks for input.
  2. 53fordcustom
    53fordcustom
    Read the rules.. Do a proper intro.. Then post your question on the main board & not the Intro page & someone will help you out... Welcome to the hamb
  3. pu_nasty
    pu_nasty
    from Houston
    Welcome from TX. Ignore these uptight B's that only get on here to gripe and play the forum Tackleberry!
  4. Hemishovel
    Hemishovel
    Welcome from WI
  5. Zener424
    Zener424
    OK, let's try this again. I was scolded a while back for not doing this right. This is Phil, from Staten Island, NY. Happy Easter to those of you that celebrate. I have a 1929 Briggs Town Sedan, rebuilt engine I did myself, and I'm still working on the 5-speed S10 trans install. I just posted a update to my original post, in the correct section of the board. Thanks for all the greetings.
  6. Devin
    Devin
    from Napa, CA
    I installed my 327 with a muncie attached in my model a. I had to elevate the front end to gain clearance so that the tail shaft had room to pivot. My radiator was removed as well. I don't see why this couldn't be accomplished with a banger and a t5. A cherry picker with an engine leveler would be a great aid as well as an extra pair of hands or two. Good luck!
  7. lorodz
    lorodz
    Do it all together .I just did a flathead to t5 ford trans very similar. Went rite in and than made the crewmember to hold the transmission in place you may have to remove the factory center cross member for clearance I cut mine out ...and made a new one ..
