Projects Model A Exhaust
Discussion in 'Traditional Hot Rods' started by lilmo630, Mar 27, 2020.
  1. lilmo630
    lilmo630
    Are there any exhaust kits out there for a 31 sedan model a with chevy 350? Any recommendations would be appreciated.
  2. studebaker46
    studebaker46
    you don't have any custom muffler shops in and around philly
  3. Model A Gomez
    Model A Gomez
    Mine has a flathead but I bought bends and welded up the exhaust to get it where I wanted it to go. Have about $200 in the system including the mufflers, but was time consuming.
    GordonC likes this.
  4. fastcar1953
    fastcar1953
    Not really any help. I use 2 inch pvc to mock it up. I have a friend with a pipe bender. I build my own.
    Might try the pvc trick and have a muffler shop bend it up for you.
  5. manyolcars
    manyolcars
    I build my own. You can get free Ubends out of a heat exchanger. My exhaust has been in daily use for about 10 years with a 460
    Jet96 likes this.
  6. This is the only type of "kit" you'll be able to find. It's exhaust shop or build it yourself.
    OLSKOOL57 likes this.
  7. studebakerjoe
    studebakerjoe
    @manyolcars , do you mean out of a hot air furnace? We get plenty of those in at work and I honestly never thought of that.
  8. fastcar1953
    fastcar1953
    Yes out of furnaces. Used them a few times myself. I'm in the hvac industry myself. armstrong-air-r38999d019-heat-exchanger-23_9a573d2c-bd52-4c36-ac4b-8e057e188ff0_large.png
    Jet96 likes this.
  9. studebakerjoe
    studebakerjoe
    909903.jpg fastcar1953, have you ever noticed that the base of some Ruud a/c units looks like an early model T turtledeck lid? Like this one.
  10. fastcar1953
    fastcar1953
    Lol. No i haven't. I'll be looking now, it's about the season.
  11. tj
    tj
    One ton trucks left side kicks in and back for extra steering clearance. Don’t remember the part number. A lot of them cracked from the weight of the exhaust not being supported. Standard rams are okay on the right side. I have also used 2 right side manifolds like the one mentioned above. By doing this the one on the left will point forward and in. The right will point back and in. This allows crossing the pipe forward and around the oil pan to the right side for single exhaust.
    fastcar1953 likes this.
  12. manyolcars
    manyolcars
    This is exactly what I have used. Its free and has held up for about 10 years in my 1960 F100 with a 460.
  13. Kevin Ardinger
    Kevin Ardinger
    Dino 64 and Moon50F3 like this.
  14. manyolcars
    manyolcars
    Is your radius road attached to your body?
  15. Kevin Ardinger
    Kevin Ardinger
    There is a gusseted bung that is welded thru the frame. The body just sits over it.
  16. Kevin Ardinger
    Kevin Ardinger
  17. manyolcars
    manyolcars
    do your front tires hit the radius rods?
    lets see the entire car
  18. Kevin Ardinger
    Kevin Ardinger
  19. lilmo630
    lilmo630
    Thanks guys, local exhaust shop is going to take care of it.
  20. Bandit Billy
    Bandit Billy
  21. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    What a cliffhanger this one was....
    Jet96 and Just Gary like this.
