model a fenders?
Discussion in 'The Hokey Ass Message Board' started by INF, Nov 24, 2011.
  1. INF
    INF
    from las vegas
    i believe the front fenders on a model a are the same just not sure on the running boards and rear fenders can anyone help? im building a 31 vicky and have a chance to buy a nice set of 31 coupe fenders and want to make sure its the correct choice.. thanks
  2. Fronts and boards are the same. The rears are different. Coupe, roadster and roadster pick up rears are the same. Sedan, touring, and vicky rears are the same.
  3. INF
    INF
    from las vegas
    ok, thank you.. ive heard the rears on a vicky are different from any of them?
  4. fiftyv8
    fiftyv8
    from CO & WA
    I think you'll find it is the splash aprons that need to match with the fenders...
  5. steves29
    steves29
    The splash apons are different but will work either way. Two piece and one piece. Check but I believe two piece is 31.
  6. 28hiboy
    28hiboy
    from Milton, Fl
    There is a lower pan that goes between the rear fenders. Synders has them is fiberglass. Rear Splash Pans
    Some of the 4-Door sedans, and the Victoria used this pan. It went under the back of the body between the two rear fenders. These were used originally, but good steel originals are getting hard...
    <TABLE><TBODY><TR><TH>Part Number</TH><TH>Specifics</TH><TH>Price</TH></TR><TR><TD class=part><LABEL><INPUT class=auto name=5992 size=3> BP-2930-MS</LABEL></TD><TD>Murray 4-dr
    1929-30</TD><TD>$155.00 / ea.</TD></TR><TR><TD class=part><LABEL><INPUT class=auto name=4510 size=3> BP-2931-BS</LABEL></TD><TD>Briggs
    1929-31</TD><TD>$140.00 / ea.</TD></TR><TR><TD class=part><LABEL><INPUT class=auto name=4511 size=3> BP-3031-V</LABEL></TD><TD>Victoria
    1930-31</TD><TD>$140.00 / ea.</TD></TR><TR><TD class=part><LABEL><INPUT class=auto name=5991 size=3> BP-31-S4D</LABEL></TD><TD>S/W 4-door
    1931-31</TD><TD>$155.00 / ea.</TD></TR></TBODY></TABLE>
    http://www.snydersantiqueauto.com/modelaparts/fiberglassparts is the link
  7. jan bogert
    jan bogert
    two piece splash aprons are 1930 '31 are one piece '31s are much nicer. besides the radiator shell, thats the dnly way to tell them apart. the insert on the top of rad. shell was painted the color of the car. :):):) in '31.
