Projects Model A Firewall clearance
Discussion in 'The Hokey Ass Message Board' started by Donut Dave, Aug 15, 2022.
  1. Donut Dave
    Donut Dave
    I’m concerned about the removal of a SBC distributor using any of the after market firewalls. I’ve built several model A’s, with this type of firewalls, luckily I never had to replace the distributor, but it would have required the engine to be removed. Any suggestions or pictures would help!
  2. SEAAIRE354
    SEAAIRE354
    I went with the flip. Not as nice looking but I needed the valve cover room and I’m not that tall so the lost leg room wasn’t that big a deal for me. Plenty of room to get the distributor out. I have pics but phone wouldn’t download them. Will try another devise if no one else responds.
    INVISIBLEKID likes this.
  3. trad27
    trad27
    The few that I have done I built the firewall myself to ensure it has the clearance I want and where. That said on a ‘28-‘29 I’ve had to unbolt the trans and jack it up a inch or so to get the dizzy to clear. In hind site that’s not very ideal for a side of road repair.
  4. Dirk35
    Dirk35
    Made my own firewall recess in my Model A based on the same size that the original builder made... as my car was originally built in its current form sometime in the 80s.
    The pic with the engine in is the before pic, but I made my the firewall recess the same size. For some reason, they used 22ga sheet and I don't think they had a sheet metal break, presumably because that is what they had available. I made mine out of 14ga sheet metal.
    Never tried to remove the distributor with the engine in, can I cannot say for sure that it has enough room for removal. Also, mine is a Sedan, so there is plenty of leg room.
    1928 Ford Sedan Engine.JPG 1928 Model A Firewall.jpg 1928 Model A Firewall 2.jpg 1928 Model A Dash 3.JPG 1928  Model A Steering column mount 6.JPG
  5. We used a *****in' firewall on my son's '31 Model A. For distributor clearance/removal we put in a section of 18 Ga. steel curved around a 6 inch pipe.....at about a 30 degree angle just behind the distributor. Do not have a better photo.....
    Maybe this photo is a bit better.....
    Almostdone likes this.
  6. Jkmar73
    Jkmar73
    from Tulare, CA
    We used a stock reproduction firewall and cut the section where the distributor and valve cover would be, and moved it back 4 1/2”. Then made a filler panel for it. There is just enough room to get the valve covers off. The distributor has to have the cap off to install or remove.
    Boling Brothers makes a panel similar to mine. I think it’s 6” deep. FE5273D4-4EBE-4A52-B1F0-3DBF837D0469.png EC3AD00D-004B-4381-85E8-9014B286E6C6.jpeg 198A41A1-71A3-4A40-AF29-00927EE0D525.jpeg A0F9BC44-8F0E-4ADB-9EE1-CE42CE16BA5D.jpeg
    Almostdone and warbird1 like this.
  7. lostone
    lostone
    from kansas
    I just lengthened the frame and moved the motor away from the firewall.
  8. dmar836
    dmar836
    Only pre-'65 SBCs and distributors will fit an A.
  9. If its a 30-31 model A just take the stock firewall out and turn it around backwards and reinstall.
    tuff57, INVISIBLEKID and Just Gary like this.
  10. D-Russ
    D-Russ
    28/29 or 30/31? They're quite different. Stock Model A frame/wheel base or something else?
    On my 31, I built a 2 inch recess that flowed along with the stock angled beads, but instead of square 90° brakes, I split 2-1/4 inch exhaust tubing lengthwise into quarters and welded them in to create a round radius going in and then back down. It looks more like a stamping that way. A 32 firewall with a little work, fits nicely in a 30/31 as well.
    Tim, 05snopro440, Bugguts and 9 others like this.
  11. Just Gary
    Just Gary
    If it's a '28-'29, you can just cut a crescent out of the top & bottom flanges.
    05snopro440 and D-Russ like this.
  12. flynbrian48
    flynbrian48
    I can, and did, pull the dizzy in this 276 DeSoto Hemi to put a Pertronix in it with room to spare. No firewall setback, it's a '32 frame and '32 radiator in stock location. 1D92FE60-5AF2-4749-BAAB-AAC753C53EA9.jpeg
  13. D-Russ
    D-Russ
    Don't forget that 32 frame, with it's 106 inch wheel base, that you and I have under our Model As gives us 2-1/2 inches more engine clearance than a Model A frame, Gary. ;) Coincidentally, an early Chrysler hemi (w/BBC water pump) is nearly the same length as a SBC with a short water pump. Ask me how I know.
    Tim, lumpy 63 and Just Gary like this.
  14. warbird1
    warbird1
    Bought this firewall as a replacement for the badly hacked up one that was in the car. This one already had the "standard" 30-31 cut and a 5" recess added. I had to extend the corners to clear the Cadillac valve covers, but reduced the recess to 2-1/2" as that's plenty of room to R&R the distributor with the cap removed... roadster firewall6.JPG roadster firewall2.JPG
    Hitchhiker and lumpy 63 like this.
  15. X-cpe
    X-cpe
    Stock wheelbase, 2 1/2" recess. Cap off, enough room to pull distributer.
  16. chessterd5
    chessterd5
    from u.s.a.
    I like the look of your roadster very much!
  17. SEAAIRE354
    SEAAIRE354
    Very nicely done. Looks like it Henry made it that way.
    D-Russ likes this.
  18. Donut Dave
    Donut Dave
    Looks great, should solve my clearance concerns.
  19. Blues4U
    Blues4U
    from So Cal
    Marty Strode has a thread on building a '29 roadster pickup, find that thread, he shows how he modified the firewall to be able to pull the distributor.
    On my 30 the firewall is modified like the one @D-Russ posted. When I pulled the distributor in order to change the intake manifold I had to pull the motor mounts and lower the front of the engine far enough for the distributor to clear. I also had to drain the radiator and pull the hoses, but I didn't have to remove the radiator itself. Kind of a *****, but how often do you pull the distributor anyway?
    bchctybob likes this.
  20. Blues4U
    Blues4U
    from So Cal
  21. bchctybob
    bchctybob
    On my '28 coupe a PO made a removeable hatch above the distributor for removal but if you pull the cap and rotor it will come out without removing the hatch door. Maybe he was planning on using a Vertex mag. Note that the firewall mod is aluminum and bolts in. Interesting and creative, I won't be changing it.
    For my roadster I made a recess that just does what I need, no big boxy recess, and radiused corners. Like D-russ, I followed the style of the stock one (somewhat). Mine's unfinished, I hope it comes out as nice as his!
    Just Gary and D-Russ like this.
  22. D-Russ
    D-Russ
    OK, it's important to note that there are infinite variables involved in creating a firewall recess that will allow removal of the distributor with the engine still in the car. Just off the top of my head there's wheelbase, amount of channel, engine position forward or back, engine position high or low, mechanical or electric fan, front cross member position, depth of recess, angle of recess, type of distributor, cap/rotor on or off, etc.
    The recess I built for my car when it had a small block Chevy did in fact allow for removal of the distributor with the engine in place, so @Blues4U , your recess was apparently not like the one I posted.:)
    Measuring and planning are important to ensure everything fits, works together is serviceable in the end.
    INVISIBLEKID, X-cpe and Just Gary like this.
  23. Blues4U
    Blues4U
    from So Cal
    This is true.
    But according to this photo, I have my doubts you could pull that distributor out.
    Here is mine:
    It's possible my engine sits at more of an angle than your's, but as far as clearance, they look pretty much the same. Maybe it's just a bad photo...
  24. D-Russ
    D-Russ
    Take a closer look – your engine sits higher than mine as evidenced by the space between tops of your plug wires and your recess. Looks to me like about an inch or so of space. There's probably 2-1/2 to 3 inches of space between the tops of my wires and the recess. Like I said, measuring and planning are important to make the vehicle serviceable. With the cap removed, I can easily pull my distributor without doing anything else for clearance.
    05snopro440 and Blues4U like this.
  25. goldmountain
    goldmountain
    To recess the firewall, I used an old Freightliner radiator tank but probably any similar size big truck copper/ br*** radiator tank will work. They are stamped steel and bolted on.
  26. Phil P
    Phil P
    Here's my set back roughed in I could get the distributor out with out the cap, but I haven't had to try since I put in my 2x3 rochesters. (or is that 3x2:D)
    D-Russ likes this.
  27. Ron Brown
    Ron Brown
    this has the frame lengthened about 1.25" and the dizzy will just slide out if you take the cap off. DA7CBF67-F87B-436D-840A-A9807CA5C9CA.png 419844AB-03AB-45F1-9044-AED0EAC752E0.png
  28. tomcat11
    tomcat11
    Yep, no clearance issues with 31 on 32 rails. Just a Bazillion other "challenges"
  29. X-cpe
    X-cpe
    Thank-You very much.
    Thank-You. There are a couple of caveats that go with it. First off it's only a 2 1/2" recess. Rulers and straight edges are more accurate than memory. Secondly, the body came with no firewall and most of the hood lip hacked off, so the face of the firewall only protrudes an 1 1/8" from the little drop where the back of the hood fits.
    Firewall and recess were beat out over a couple of hammer forms using 16 ga. hot rolled. (Didn't know any better at the time.) I put a small lip on the firewall section where it meets up with the recess. The recess has a 2" radius.
    D-Russ likes this.
