Model A Firewall help
Discussion in 'The Hokey Ass Message Board' started by kaboom, Nov 6, 2010.
  1. kaboom
    kaboom
    from STL, Mo
    Im trying to get the firewall out of my 31 model a sedan so I can start on the frame. I un-bolted everything and ground down the rivets but it wont budge. I was thinking it was probably seam-sealed in there. Is there a trick to getting these out besides heating them up to melt the seam sealer. Help me Henry Ford!
  2. Drive a rigid putty knife between the firewall and the body panels. They usually don't come out peacefully.
  3. there are spot welds , many of them. they are hard to see but if you run a bit of sandpaper over them you nay be able to see them
  4. billthx138
    billthx138
    Should be just a bunch of spot welds. When I worked on mine just about the time I thought it should be loose I found another. There is a body man tool for splitting panels that have been spot welded. You can find them in the Eastwood catalogue or make one your self. basically, it is a flat thin bar steel and you shim it between the panels and the strike the bar with hammer to split the two.
    http://www.eastwood.com/smacker-whacker-seam-buster-kit-3pc.html
