Technical Model A Flathead install instructions
Discussion in 'Traditional Hot Rods' started by DreamerJ, Jan 10, 2024.
Tags:
  1. DreamerJ
    DreamerJ
    Forgive me for not knowing where to find this info but can someone point me to where I can find step by step instructions on putting an 8ba or 59ab in my 1930 highboy roadster?
    websites?
    Books?
    Personal advice?
    my banger is dead and it’s time for the v8.
    I ask about both v8 installs because I own both engines and unsure on which one I’ll install.
    thanks for any help!
  2. DreamerJ
    DreamerJ
    Thnx I bought the book.
    throughbeingcool and alanp561 like this.
  3. That book is known to have incorrect measurements and hole sizes for the motor mounts. Use it as a guide but you will still need to mock up all of your bits and pieces to verify that everything is playing nicely so it will work together. Don't be in a hurry to do this since it sounds like it's your first time, it is not a difficult job but it can frustrating when things don't work out right away. The engine, once in place, looks like it was made for the swap.
    throughbeingcool, ydopen and alanp561 like this.
  4. cederholm
    cederholm
    I'm in the process of doing this now following Tardel's formula (mostly). Feel free to poke through my build thread - this is a first for me so take it with a grain of salt.
  5. Model A Gomez
    Model A Gomez
    I used the Tardel book when I built my avatar in the mid 90's and when I built my 30 Sport Coupe about five years ago but changed a few things. I built a rear crossmember for the transmission from 2"x2" square tubing, used the stock Model A pedals and a few other small changes but the book is a great help. As noted in the other replies check all the measurements on your car, every car is a little different.
  6. Hotrodmyk
    Hotrodmyk
    Check out @IRON Trap. On his YouTube channel, he put a flathead in an RPU that turned out pretty cool.
    throughbeingcool likes this.
  7. I believe he used the Old Yankee Speed Co. kit.
    Here's another video of someone using the OYSC mounts:
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    It's easier to do than you think. Don't over think it and MEASURE...MEASURE...MEASURE.
    DreamerJ likes this.
  9. RodStRace
    RodStRace
    Another source that will take a bit of time but prove to be full of tidbits is to go to the top of this page, click on the little magnifying gl*** to the left and type in AV8. Read the results. This will be even more help if you either copy and paste stuff into a do***ent on your computer of write it down on paper (the vintage HAMB approved way!).
    alanp561 likes this.
  10. wheeldog57
    wheeldog57
    Wifey bought me the Tardel book right after I finished the roadster and I definitely checked it out. Turns out I did a lot of the same things that the book illustrates. Hardest parts (to me) was pedals, steering set up and angle, and shortening the torque tube. If I can do it then you can do it. "Something from nothing 29 roadster build" good luck and ask many questions
    DreamerJ and J.Ukrop like this.
