Projects Model A Ford Pickup Build
Discussion in 'The Hokey Ass Message Board' started by Wiseguy82, Jul 27, 2020.
  1. hotrodlane
    hotrodlane
    Looks like a very solid truck you started with. Does the serial number on your 1929 ***le match the frame you have? I only ask this because your Cab, fenders and radiator shell are not 1929. They are 1930 and your Splash aprons are 1931. If your ***le says 1929 then it would have to because of a previous engine swap sometime in it's life and it was registered using the replacement 1929 engine, Or that body you have was put over on the 1929 frame. The reason I am bringing this up is If your frame serial number does not match your ***le Seeing as how you have replaced the 1929 model A engine You have nothing legit that proves ownership of your truck. And stuff like this for the last few years has been becoming serious problems for guys. Basically for anyone who knows their fords if you tell them your truck is a 1929 a Red flag is going up immediately do to nothing about it looks like a 1929. Not trying to sound Negative I just don't want you to get your truck impounded with No proof of ownership to get it back.
  2. Wiseguy82
    Wiseguy82
    from Wisconsin
    So, I finally have possession of the ***le from my father and to my surprise, it states it’s a 1930, so I guess I’m in luck there. Examining the ***le, it shows the engine number but what number would match the frame? There is a faint remainder of stamped numbers on the driver’s side engine compartment area that could be a match if I knew better what I was looking for. Thoughts?...
    osage orange likes this.
  3. hotrodlane
    hotrodlane
    If the engine is original then the number on the frame will be the same.
  4. 31Apickup
    31Apickup
    The serial number on the frame should be on the drivers side under the cowl. All model A engines were built at the River Rouge plant in Dearborn MI. The serial number was stamped on the engine, then the engine was shipped to one of the ***embly plants. When the engine was put into the ch***is, the engine serial number was then stamped on the frame.
  5. 33 fuel
    33 fuel
    Question on the model a build
    in this picture i have the same frame in my 31 A pickup. The welded on radiused support tabs beside the upper shock mounts, that support the wood frame of the box keep cracking on my truck. Right at the weld .This will be the 3rd time I've had to weld them this year . Any body else have this problem ? and if so ... how did you remedy it ? thanks for the help im thinking of going with thicker mtl .and a longer bracket under the frame ,Not just along the edge
  6. 31Apickup
    31Apickup
    Do you have bump stops on your axle to keep from bottoming out the coil overs. Usually see mounts crack or the mounting bolts bend do to that.
    33 fuel likes this.
  7. 33 fuel
    33 fuel
    Thanks for the reply . Truck did have a crazy 250 pound heavy coil over spring in it . I Put 150 pounds in it made it nicer to drive . But still box tabs kept breaking . will try the bump stops . thanks again extra set of eyes are helpfull
