Technical Model A Ford Sediment Bowl
Discussion in 'The Hokey Ass Message Board' started by deluxe coupe, Feb 24, 2024.
  1. deluxe coupe
    deluxe coupe
    I have the gl*** sediment bowl, and I am trying to connect it to the fuel shut off value. Now I have a 1931 Deluxe Coupe with the indented firewall. So the shut off is under the hood. I know I should have a Zenith carb and the cast iron sediment bowl, however I do not. I have the Tilloston and a gl*** sediment bowl. Can someone ***ist me with the proper information on how or what fittings were used for the gl*** sediment bowls? I will use this till I can purchase a zenith with the cast iron sediment bowl. Thank you in advance.
