Model A Ford VIN Identification
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, May 5, 2008.
  1. TACOS29TUDOR
    TACOS29TUDOR
    yes 36-3 window i sure did, got it in october, sold my 2000 Roush mustang and bought an old toy, now i found out today that my bank lost my ***le between my branch and the main headquarters downtown, a grand total of around 10 blocks lol whats next...... i just wanted to know if the 8 was supposed to be an a instead so in case i need to go back to minnesota and apply for a duplicate ***le. thanks all!!
  2. Nobey
    Nobey
    Question? I'm building a 28 roadster and found a guy with a frame and
    no ***le. Can I check the Vin on line or do I take the number to the D.M.V.?
    Don't want to get stuck......
  3. PGraham55
    PGraham55
    Great info, Thank you
  4. RustyNCA
    RustyNCA
    So if my 29 has a number that falls in the Feb 1930 range? The body is without a doubt a 28/29 body, but the VIN is A2922**x.
    sure would be nice if I could find a chart like this for the 34 Dodge truck we have that is missing the tag in the door jamb and the paperwork was lost when the owner moved....
    Cheers
    RustyNCA
  5. daveinaustin
    daveinaustin
    Hi need some help hambers!
    Just discovered the ford body has the following stamped on the firewall "w9748"
    the body was originally a 4 dr phaeton. Now its a 2 dr.
    Can anyone help point me in the right direction?
  6. Bruce Lancaster
    Bruce Lancaster
    On the '29...MANY A's are registered under the number found on a random rebuilt engine put in decades ago.* If that is the case frame # should be the right one, though the later frame fits nicely under a '29 too. Frame # is of course frequently rusted to hell, and some are entirely absent on fresh clean frames.
    Body # like that is something from body ***embly or ***embly line procedures, and has nothing to do with legal serial, though many creative folks have gotten through muddled DMV procedures by pointing to those!
    * Note the danger here...the car the engine came from could still be running around somewhere still registered under its correct number. These things have a pretty big survival rate...
  7. silversink
    silversink
    Where are you located? I just bought a 29 that was out of Yakama Wash . I have to also ***le mine but I do have the original motor it just isn't in the car(laying on the floor).
    I am located across from Cruicshank rd. on loop rd in Dayton
  8. Mr48chev
    He posted that July 11, 2012 so he probably has it taken care of now.
  9. Jacob Eberhart
    Jacob Eberhart
  10. Bikelessbill
    Bikelessbill
    I hate to jump in on someone else's post but I am working on a Model A frame with no numbers due to weathering and a Model A cowl with no numbers that I can find. Is there anything I can do or should I find numbered parts. Thanks Bill.
  11. Quote I hate to jump in on someone else's post but I am working on a Model A frame with no numbers due to weathering and a Model A cowl with no numbers that I can find. Is there anything I can do or should I find numbered parts. Thanks Bill.
    Some Canadian frames came without numbers. First lets be sure you are looking in the correct place, see http://jmodela.coffeecup.com/numbers.html Sometimes the numbers can be raised using acid, see archives. There are no serial/VIN numbers on the cowl. There was a plate attached with four rivets that showed the patents used to build the car. If the body was built by someone other than Ford (subcontracted) there was a body number plate that was not used for identifying the completed vehicle (some DMV's have used this number but shouldn't have).
    Charlie Stephens
