Technical Model A Frame, ‘36 Rear Spring
Discussion in 'Traditional Hot Rods' started by gbgh, Dec 30, 2020.
  1. gbgh
    gbgh
    I want to lower the ch***is in my’30 Roadster. Front has a 4” drop. Is a the arch in a ‘36 rear spring tall enough to allow enough clearance for a banjo diff or a Halibrand rear without modifying the frame?
  2. rudestude
    rudestude
    I believe it will move your rear end forward due to the shape of the spring , if your running fenders things are not going to line up.
    Sent from my SM-T387V using The H.A.M.B. mobile app
  3. Doubt it. The 36 If I recall right was mounted behind the diff. It fits a crossmember thats much flatter,and down in the center.It wont fit the A rear crossmember which is very raised in the center. The A spring is over the axle.You could remove a leaf,and reverse the spring eyes to get it down a couple inches.
  4. Limey Kid
    Limey Kid
    Using a T spring in the rear will lower it about 4"
    irishsteve likes this.
