Model A Frame and Front Suspension Plus
Discussion in 'Parts For Sale' started by LM14, Jul 29, 2018.
  1. LM14
    LM14
    from Iowa
    City: Bloomfield
    State: Iowa
    Price: 3500
    Got this in a trade deal and I will never build it. Great start to a hot rod or rat rod build. This frame would work under a lot of styles and models of cars/trucks. All new stuff (except the rearend housing).
    Professionally built perimeter Model A frame with all the body mount nuts welded in and most of the body/hood latch mounts welded on. Kickout behind the rearend center section. Also includes a 4" drop spring behind front tube axle setup with spring (also a spare spring) hairpin radius rods, Ford spindles and a disc brake kit. Also has a Vega steering box, weld on brake pedal setup, weld on front shock/headlight mounts and a set of headlights. Pretty complete frame and front suspension setup. NO rear suspension.
    This frame deal also includes a MAGNESIUM Jones Quick Change rear end housing to build. I kept these rearend parts for a future build but will not be able to use them as my build days are numbered. It's empty but Jones takes the same loaded ring and pinion as Winters/Franklin. It has 8 rib side bells that are really nice and almost new, we swapped them out for lighter bells within the first year of running these side bells. No guts, just the center housing and both side bells. Very buildable and simple to do. Any circle track shop should be able to handle it or walk you thru it. They are really very simple. Remember, this is a Magnesium rearend housing and bells, not cheaper aluminum pieces.
    Everything listed for $3500. Will provide bill of sale if wanted. Not much wiggle room, just want it gone.
    Also have a set of black roadster style headers for a small block Chevy, standard port style head. Cost $250, if you want them with the frame I'll let them go for an additional $200 over the price of the frame kit.
    Call, text, Email. Any time. Have a trailer and delivery can be arranged AFTER you pay for it. Drive down in your car, check it out, pay and help load and I'll haul it within reasonable distance. What a deal!
    The 32 body sitting beside it is sold.
    Thanks for looking.
    frame5.png frame1.jpg frame2.jpg frame3.jpg frame4.png frame6.png frame7.png frame8.png frame9.png frame10.png frame11.png frame12.png qc2.jpg qc1.jpg qc3.jpg trade4a.png trade22.png trade22a.png trade25.png trade28.png
