Model A frame horn drawing
Discussion in 'The Hokey Ass Message Board' started by rpu28, Jul 2, 2012.
  1. rpu28
    rpu28
    from Austin
    Does anyone have a dimensioned drawing for Model A front frame horns?
  2. Ben DeBumper
    Ben DeBumper
    Is this any help?
  3. rpu28
    rpu28
    from Austin
    Thanks, Ben, but not quite enough info to make a reproduction.
  4. adam401
    adam401
    I think I have a pair I picked up at my garage. I'll be going there late on to work on my car. Do you just need a pair?. If I can come up with them (I may have given them to my buddy so no promises) you can have em for the price of the ride. Let me know.
  5. Paul
    Paul
    Editor
    pdf work for you?
  6. 48fordnut
    48fordnut
    I used a drawing like that to make a plywood pattern that is very good when put up to a model a frame. Send me 10 bucks for postage and I will put your name on it and send. Its about 30'' long on 3/4 ply.
  7. I have a pair of them here, I could create them in a 3D solid form you could machine your dies from.
  8. Paul
    Paul
    Editor
    or dwg?
  9. rpu28
    rpu28
    from Austin
    Paul,
    Thanks for drawing.
    Does the 9 1/2" dimension in your drawing refer to the center of the 1" radius circle?
    Also, the radius describing the upper arc of the horn is 1' 11 9/16"; add the 2 9/16" horn width and you get 26 1/8", which is almost the same as the 26" radius describing the lower horn arc - do you think they are supposed to be the same? Is it a question of where the 2 9/16" dimension refers?
    And do you have a reference on the x-axis, such as a rivet hole for the front cross member?
  10. fxdwg05
    fxdwg05
    48fordnut do you still have patterns for the frame horns? I can't get the one from this
    post to open its DWG.
  11. Paul
    Paul
    Editor
    Go up a couple posts for the .pdf version
  12. Mr48chev
    The PFD is a bit tricky to open but it will open.
  13. Paul
    Paul
    Editor
  14. Paul
    Paul
    Editor
    Chucky likes this.
