I'm starting to build a frame for a 31 pickup and used the wescotts frame dimensions, but I couldn't figure out how to do the frame horns. I figured out that if you zoom the pdf to 1660% and print the current view in landscape mode on 8.5 x 11 paper the printed image comes out to correct measurements. It took about 4 pages to make a full size image. Then i taped the pages together to match and cut it out. I want to z the front end but I'm not for sure how far back I should start the z. I also want to add about 3 or 4 inches in the front to help with engine spacing. Any help would be great. This is my first hot rod.
http://www.jalopyjournal.com/forum/showthread.php?t=98330&highlight=test http://www.jalopyjournal.com/forum/showthread.php?t=87556&highlight=frame
