Projects Model A frame mock up/visualization
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, Mar 20, 2014.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    After cleaning out nearly all the frame, channel and all, did a mock up with my restored front axle... no A cab yet, but working with Ford specs and Yblock measurements to get an idea of where things'll go on my first A rod...
    Planning a kick-up for the back to go with channelled body, what is a good kickup height for a lowboy? How far back did you lean yours back? Planning, running that tape and visualizing eagerly...
  2. scrap metal 48
    scrap metal 48
    Sounds like you have a plan.. What's the axle off of?? Looks pretty wide.. How do you plan on mounting your spring to that axle?? Inquiring minds want to know...
  3. From where I sit you either have a plan all your own or headed for a learning curve. You say "restored front axle" so I take it to mean your going to use it. So quarter elipitic springs must be on your list as well as a very long wheel base. Also looking at the Axle and where it is, what ever your doing will be fender less (even if you move the axle back where it started). So bring us up to speed on the rest of your vision.
    The Wizzard
  4. HOTRODPRIMER
    HOTRODPRIMER
    Your axle looks too wide,even if you plan on using dual leaf springs up front.HRP
  5. Angry Frenchman
    Angry Frenchman
    axle looks wrong to me and too far forward even for a T bucket. Do you have any pics of what your shooting for?
  6. 53OlderThanMe
    53OlderThanMe
    I'm guessing 53-56 F100 straight axle.
  7. Grudge
    Grudge
    You said cab so I ***ume you're building a pickup? A pickup with a Y-block would be cool, but yeah, that front axle is huge!
    If you're building a pickup you can check out my build thread and many other (even better) threads for ch***is layout ideas.
    Good luck!
    Aaron
  8. Woob
    Woob
    from Falcon, CO
    These transverse spring brackets didn't work because their width interfered with the frame. Yours won't interfere because they'll be outside. ;^)
  9. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    '63 F100. Was actually in a parts truck I had for my '57. Quarter elliptic spring set up is the plan.
  10. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Thanks, Aaron, yep Mod A pickup lowboy is the plan
  11. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Good to know!
    What axle/axle dimension was that one?
  12. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Having trouble posting pics from my source, some particular As I photog'ed at a show a coupla years ago, tryin to resize to post... or find another example from the net... Albeit that Mod A's suicide front end had the leaf spring across the front... love the forward-placed look of a lowboy... Wheelbase would be naturally elongated from having the axle a bit forward, possibly elongated by the kick-up in the back.
    So what height is average for a kick-up, would you say? What height is crazy? Lookin for a scale to this.
  13. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Naturally not finding lowboy trucks on the Net... with quarter-ellip springs before heading to Work, but to give you an idea... Will try more later today.
  14. pdunn10
    pdunn10
    Your current axle will not look right on a suicide front. Everyone you see has either a tube axle up front or an original style A / Dropped axle without the platforms for the springs. you could do something to make it look better but the axle you have out front would not be the best looking one you could choose. Model A axles can be had cheap!
  15. ididntdoit1960
    ididntdoit1960
    from Western MA
    I agree with the above comment - I wouldnt use the axle "just because you have it" I've fallen victem to this before and had to pay for it later (in time and $$) the right parts are available cheap - sell that axle to someone with a pickup....
  16. Holly Cow!!! I'm going to stop there. The Wizzard
  17. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Food for thought, thanks... so what is a recommended height of rear kickup? What angle or height have you used in making one?
  18. willymakeit
    willymakeit
    There is a thread on here where an A100 axle was used with QE springs in a Model A sedan. Was out of Topeka Ks.
  19. pdunn10
    pdunn10
    How low do you want it? I would get the front figured out. And then determine the amount of rake you want before messing with the rear.
  20. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Huh, will have to dig it up, thanks.
  21. sadsack
    sadsack
    keep at it.
    sadsack
  22. pdunn10
    pdunn10
    the traditional way to kick up, was to cut the rear cross member off and have the bottom of the cut off section be even with the top of the front section. was good for 3 or so inches, add that to a spring that is dropped (with spring eyes or stretched t spring and you are down a few more.)
    We are not trying to deflate you on the axle we just have an eye out for issues, We don't want to have you build it a few times just to get it right if you don't have to.
  23. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  24. Angry Frenchman
    Angry Frenchman
    Homboldt, Do you have a rear axle and trans in mind? The more kick in the frame you have the more the drive shaft will be in the cab with ya.
  25. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Sold the '63 axle to a friend, acquired a Mod A axle this week
  26. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Pics soon, been workin with it on Lunch breaks at Work... someone split the steering rod and welded halves to the beam to convert as trailer axle... there is a different one I have a line on, but can use this for mock/dimensions in the meanwhile....
    Angry Frenchman: I figured either a Ford 9" or S10 rear to hook up to with the YBlock and auto trans-to-be... something not too much but sturdy enough to take that stock V8...
  27. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Pics of the A axle, the day I scored it... have since gotten much of the rod material that's welded at the center trimmed, got the backing plates off yesterday (the bolts were suprisingly cooperative).
  28. RICH B
    RICH B
    Thats actually a '37 or '38 axle.
  29. johnny bondo
    johnny bondo
    from illinois
    yep, wishbone mounts are closer to the kingpins and has more bend twords the ends. axles are kinda useless on anything but a stocker, but the spindles are what you want for hydraulic brakes!
    note:the reason i say its useless on anything but stock is because youd have to order a special spring to do spring on top, and if you split the wishbones on those you greatly lose turning radius. but i have seen people run them.
  30. Angry Frenchman
    Angry Frenchman
    those spindles are nice! just need a v8 axle, good score!
