Hot Rods Model A frame
Discussion in 'The Hokey Ass Message Board' started by don daddyo, Apr 20, 2023.
  1. don daddyo
    don daddyo
    Is it me or there is something I'm not catching about building a 1929 Roadster with it's original frame , when most of those I've seen are built with a 32 frame...?Oh ! I know that I will stay with the original frame but I had to ask about it...Don
  2. sdluck
    sdluck
    Mine has the original frame,
  3. Dirty Dug
    Dirty Dug
    Is there a question in there somewhere? A lot of Model As are built on original frames.
    Just Gary likes this.
  4. Just depends on the look you want.Theres a long running thread here about A"s on A frames. Lots of photos.
  5. X-cpe
    X-cpe
    32 has a 3" longer wheelbase. Can give you more leg room.
    anthony myrick likes this.
  6. ^^^^^and helps that v8 to fit a little better
    X-cpe likes this.
  7. One reason for the 32 ch***is is the look.
    The other could be it’s sturdier than the A
    X-cpe likes this.
  8. dwollam
    dwollam
    Right now I have 5 model A's with Model A frames and 1 '32 Sedan with '32 frame.
    Dave
    oliver westlund likes this.
  9. '29 Gizmo
    '29 Gizmo
    from UK
    32 frame is MUCH stronger in stock form and has all the fittings for a V8. The model A has no K member so ideally needs additional strengthening for rodding purposes. All down to what you want and what you plan on doing with it. I think a lot of model A roadsters ended up on 32 frames because it was the cheapest way to get a V8 roadster as 32 roadsters were rare.
  10. millersgarage
    millersgarage
    32 is stronger than an A, longer means more engine room too.
  11. A Boner
    A Boner
    Mostly about aesthetics! Opinions differ.
    warbird1 likes this.
