Projects model a frame
Discussion in 'The Hokey Ass Message Board' started by 33_chevy, Nov 1, 2010.
  1. 33_chevy
    33_chevy
    from TX
    So this is my first try at a frame,i am building it for my 30 model a coupe body.I don't have allot of room in my small garage or any fancy tools.I have the front end monted and am currently working on the rear.After this i am planning on mounting motor and trany.
  2. tb33anda3rd
    tb33anda3rd
  3. scrap metal 48
    scrap metal 48
    Small spaces.. Crude tools.. Now that is hot rodding at its best........
  4. 33_chevy
    33_chevy
    from TX
    Here are some updated shots...My garage is really small...
  5. ckunsman89
    ckunsman89
    from cocoa, FL.
    looks pretty good. i'm running a similar setup for my 22 studebaker cab.
  6. 33_chevy
    33_chevy
    from TX
    I did stretch the frame 4" for motor clearence..I want to run the original firewall
  7. fergie059
    fergie059
    from ohio
    Refreshing to see a no "excuses" builder. Looks like a great start.
  8. 33_chevy
    33_chevy
    from TX
  9. 33_chevy
    33_chevy
    from TX
    Just some more shots..Motor and ****** going in soon,will have to set up some brake and clutch pedals..
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Lookin great! Did you gusset those Z welds internally?
  11. Nice job. Looks good.
  12. Thirtycoup
    Thirtycoup
    What he said...... you would be well served to put gussets on those weld joints on the Z. Rest of project looks good though, good luck with it.
    Mike
  13. scott 351 wins
    scott 351 wins
    fish plate those 45* joints, nice job.
  14. 33_chevy
    33_chevy
    from TX
    Here's more shots,just got the motor set in today..garage is gettin smaller and smaller..I still gotta fish plate the 45's..I appreciate all the advice..
  15. Iceberg460
    Iceberg460
    Lookin good man. I like what you did with the rear crossmember, never seen a stock one grafted in like that before.
  16. Very nice work!! Like the carb setup too. Your gonna have a ride you will be proud of. Todd
  17. 33_chevy
    33_chevy
    from TX
  18. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    I was gonna ask about that. Did you save a hacked up rear cross member?
  19. fiftyv8
    fiftyv8
    from CO & WA
  20. 33_chevy
    33_chevy
    from TX
    The rear cross was hacked up i got it from a friend and was already cut,so i cut out the tubing and trimmed a only a little and set it inside the tubing..
  21. 33_chevy
    33_chevy
    from TX
    The body is in really sad shape,i really have my work cut out.The cowl section is pretty much gone as well as the top section.I just bought a complete top that was cut from a car and i will try and piece it together.I will try and send some shots of the body..
  22. chrisntx
    chrisntx
    from Texas .
    how thick is the wall of the tubing you used for the frame?
  23. 33_chevy
    33_chevy
    from TX
    Here's what i am working with..
  24. 33_chevy
    33_chevy
    from TX
  25. 33_chevy
    33_chevy
    from TX
    The body was pretty much headed for the s**** and i picked it up cheap...I did find some doors also..
  26. Hitchhiker
    Hitchhiker
    Damn! that makes my body look mint! You are a braver man than I.
  27. mason71
    mason71
    from Edmond, OK
    nice work man I hope it continues to come together well
  28. general gow
    general gow
    MODERATOR
    oh, that poor thing. looks like it was a neat hot rod at one point. good luck bringing it back.
  29. atch
    atch
    which cowl/firewall will the final version use?
  30. 33_chevy
    33_chevy
    from TX
    The one sitting on the frame is the one i will use.This appeared to be a 50's hot rod,it was sitting on a frame which i sold and decided to build my own.It was channeled 4" and chopped 5" and i plan on keeping it this way..I have the complete wood kit doors,cowl,and complete top.I don't have a deck lid..I also have some patch panels.The area below the rear window is really bad,and i will have to figure something on that..I just couldn't see this thing go to the s****...I must be insane.
