Technical Model A front axle!
Discussion in 'Traditional Hot Rods' started by KahunaKat, Aug 27, 2023.
  1. KahunaKat
    KahunaKat
    from Texas
    I'm building a 31 Ford coupe street g***er and I was wondering can you use a model a axle on it
    with later spindles, new spring, and kingpins?
  2. Fordors
    Fordors
    Sure, just be sure the king pins match the spindles. The so called round back ‘37-‘41 spindles use a k/p that is 1/2” shorter that the ‘42-‘48 square back spindles. Also be aware that there are shorter springs for some aftermarket dropped axles that are narrower. I realize you won’t be using a dropped axle on your “g***er”, just be sure to get the proper spring length.
    31Apickup, lurker mick and -Brent- like this.
  3. KahunaKat
    KahunaKat
    from Texas
