Hot Rods model A front cross member question
Discussion in 'The Hokey Ass Message Board' started by maddog, Jan 18, 2023.
  1. maddog
    maddog
    from So Cal
    Building a 29 model A Tudor Sedan. I am using a dropped front axle and split wishbones all typical stuff. With the back of the car sitting a bit higher how do I get the correct fit of the front spring to the cross member?
    Do I need to cut it loose and re-weld to get a good fit that doesn't twist the spring or shackles while achieving proper caster? A wedge?
    I know y'all have done it many times and probably in different ways.
    I'd love to hear your favorites.
  2. Pete Eastwood
    Pete Eastwood
    from california
    You're over thinking it.
    If the car sits on a normal "hot rod rake,
    the crossmember will be just fine.
    There is already a bit of caster built into the stock cross member.
    You would have to have a pretty extreme rake to necessitate a change
  3. 1946caddy
    1946caddy
    from washington
  4. maddog
    maddog
    from So Cal
    As usual, you guys are great. Thanks
  5. alchemy
    alchemy
    Springs bend as they work, that's what they do. A couple extra degrees at the max isn't going to ruin anything.
  6. fiftyv8
    fiftyv8
    from CO & WA
    No pic's so not 100% sure but if you are concerned about rake it might be that you need to step your ch***is at the rear to allow for levelling adjustment for rake and to prevent the diff hitting the ch***is rails.
    Take a look at some of the after market ch***is's on offer to help you get your head around it.
    Good luck with your build and keep posting and/or asking questions...
      174.3 KB
  7. clem
    clem
    Set ch***is up at ride height, put angle finder on top of cross member.
    Match that angle to castor 90 degrees. Castor usually 5 - 10 degrees depending on who you ask.
    ( I used 7 degrees as that’s what the majority said at the time).
    I never did this when I built my ch***is originally and after a few test runs the spring was going in directions that I didn’t like, so I tweaked the cross member afterwards rather than put a wedge in it.
