Technical Model A front crossmember in a 33 pu?
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Nov 18, 2025.
  1. bchctybob
    bchctybob
    I’m spending some quality time with my ‘33 pickup. It will have a dropped stock type axle, spring and hairpins. I’ve done the crossmember mod that drops the front around 1”- 1 1/4” in the past but on this ch***is the PO drilled out the rivets and installed bolts.
    Since it’s kinda half way removed already, I was thinking of removing the ‘33 crossmember and installing the Model A crossmember that I have. It looks like an easy 2” drop since I’m already doing major surgery. Anyone ever done this or seen it done?
    I’ll be cleaning up the frame and installing boxing plates so now’s the time. The cab is channeled 2 1/2” so I will have some work to do with the radiator, grille and hood.
    Just wondering if there’s something I’m not seeing that makes it a bad idea.
    Yeah, I know, the boxing plates go on the inside. Lol
    porkshop and chryslerfan55 like this.
  2. krylon32
    krylon32
    from Nebraska
    I did a 33/34 ch***is for a customer in Italy years ago who had some specs and a parts list he wanted used and one of them was a model A front cross member in a specified spot. He was building his idea of a Jimmy Shine truck?.
    porkshop likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    If it will be sitting Low with A crossmember , Check look ahead
    Few step's , I am thinking deep C notch
    So maybe boxing with 3/16 in
    that Area?
    porkshop and bchctybob like this.
  4. bchctybob
    bchctybob
    Yep, I figured that there might be a couple C notches required to take full advantage of it. The frame rail is a little taller than the 32 or Model A in that area.
