model a front end ..stuck
Discussion in 'The Hokey Ass Message Board' started by flake, Sep 23, 2005.
  1. flake
    flake
    hey guys im building a 31 dodge my first roadster...anyways im stuck on the front part of the suspension ..im trying to suicide the front end ..can you guy sens some pics of your suspension so i can see and give me a better idea ?...oh and what degree do i set the front axle? 7
  2. BRENT in 10-uh-C
    BRENT in 10-uh-C
    I guess I am having a little difficulty with your question too. Your title says Model A (Ford ??) and then you say that you are building a '31 Dodge (model DH??). The set-up on those two are totally different. The Dodge uses a parallel front spring set-up (two springs side-by-side) --and the Model A uses a tranverse front spring (aligns with the front axle). IMO you need to decide which set-up you are planning to use. THEN a front axle can be chosen.
  3. flake
    flake
    its a dodge body on model a frame is what i meant to say ...anyways i figured it out thanks anyways
  4. Unkl Ian
    Unkl Ian
