Model A front X-member ????
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Mar 30, 2004.
  1. Mike Paul
    Mike Paul
    I want to get the front of my car lower without Z'ing the front rails so I'm getting rid of my cracked and broken stock front crossmember and replacing it with a flat home built crossmember. What do you guys usually use? C-channel? Square tubing with the bottom cut out? looking for suggestions on the safest way to make it.
    I allready know I'll have to knotch the frame and run a reverse eye spring....Thanks....Mike
  2. general gow
    general gow
    MODERATOR
    how am I supposed to read your post with an avitar like that?
  3. 201
    201
    Wow, those things will hipnotize you!
  4. Mike Paul
    Mike Paul
    Sorry,I can change it if you guys want me to. "OR" I can post more, It's up to you guys. I hope nobody is offended.
  5. Levis Classic
    Levis Classic
    What was your question again?
  6. manyolcars
    manyolcars
    The only way to stop being so offensive is to make the avatar larger
  7. bradberry00
    bradberry00
    ***** *******s [​IMG] ...this is a good question....I wouldn't mind knowing this too...the repop crossmembers are a rip off.....
  8. Oilcan Harry
    Oilcan Harry
    from INDY
    Wonder if she needs any help with those. (*)(*)
  9. 34Fordtk
    34Fordtk
    HUH??.....OH yeah the question for about $50 a repo aint a bad deal I think. You could use "C" for it if you wanted.BTW right click "save as"!
  10. Detonator
    Detonator
    from santa cruz
    Whatever you wind up using, be sure to dial some caster into your geometry when you weld it in. [​IMG]
  11. lowsquire
    lowsquire
    from Austin, TX
    there are pics of building one on this site...
    http://www.the-antidote.com/one/1ch***01.htm
    I did mine just the same, but added a thick strip along the back edge.
    Im running a spring behind the axle,mounted to split bones, this drops you down another 3 inches.
    still havent notched the frame, but may have to.
  12. Very nice Lowsquire.
    I think the axle out front like that will give the car some good lines.
    Far as the original question goes, why not give some thought to running a rectangular tubing front crossmember and doing the suicide bit like the car in the pic?
    Granted, this is a tube framed car, but the front end setup would work for you.
    And like Lowsquire, give you a nice look as well as getting the car down a bit.
    Don't go too low though, a little practicality is required if you really want to drive it.
  13. flt-blk
    flt-blk
    from IL
    67ImpWagon is running a piece of straight U channel in
    place of his crossmember. It will require a custom
    Radiator mount, but that's not a big deal.
    I like the frame notch at the firewall in the first pic, it
    looks a little cleaner than a Z.
    TZ
  14. dixiedog
    dixiedog
    C9 do you have a side shot of that car? I would like to see how it all "fits" together -
    That AVATAR is the best!!! saved it to the hard drive
  15. Not a full side shot, but maybe it'll help.
  16. Here's a front shot.
  17. dixiedog
    dixiedog
    Thanks C9 - pretty neat frame work there. It looks like it is too far forward for that year style. But, that is some beautiful craftsman ship.
