Has anyone been able to adapt a modern electric sending unit to a stock Ford Model A tank? If so, please share what you did. Thanks. Doug
YES! On the "Stupid Car" I put an electric pump down on the frame. Remember to keep it as far away from the exhaust as possible or put a heat shield on. I than ran the gas line back up through the floor board and out the original hole and through to stock gl*** bowel filter. All looks very stock. You should run a pressure regulator and might need a little better in line filter than the stock A. Hope this helps.
Thanks for the reply. I am trying to adapt an electric sending unit to the tank to operate an electric fuel guage in place of the original mechanical float guage. Any udeas?
