Model A glass thickness???
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Feb 3, 2005.
  1. Mike Paul
    Mike Paul
    I'm going to have the place we get our gl*** from at work cut me some laminated safety gl*** for my chopped windshield frame. My question is how thick total should the gl*** be? What do I use to glaze it? Silicone? Rubber? Thanks....Mike
  2. oldspeed
    oldspeed
    from Upstate NY
    I can't help you on the thickness, I just had a gl*** company use standard flat gl***, but the first one they used Urathane (sp) to set in place in the frame, the frame peeled it's chrome and I had to destrory the gl*** and frame before I junked it. The second winshield in a Aluminum replacement frame was set in place with the original model A windield cork material, no leaks and if I ever break a winshiels gl*** I know I can get it out without damage.
  3. jusjunk
    jusjunk
    from Michigan
    The gl*** shop should be able to fix u up. Its near a 1/4 but I cant remember if it is actually a 1/4 inch. Its standard though. Ive set em with silicone and the setting tape. For a windshield in the frame id use the tape.
    Dave
  4. orcas tow
    orcas tow
    Mine measured .200" & seemed to fit the frame fine, it was not the origonal gl*** though.
  5. old beet
    old beet
    We call it 1/4 inch, but because of the Metric System its a C hair under...........OLDBEET
