Hot Rods Model A guys, what did you do for welt between tank and cowl?
Discussion in 'The Hokey Ass Message Board' started by scoop, Jun 30, 2021.
  1. scoop
    scoop
    Title says it all. Did you use welt or seal the seam some other way?
  2. Used several rows of friction tape. Be sure to use something.
  3. woodiewagon46
    woodiewagon46
    from New York
    If you do decide to use the welting, the Model A cowl welting is smaller than the typical fender welt. The problem with the welting is that it goes from the bottom of the cowl, over the gas tank and down to the other side of the cowl. The cowl is riveted in the lower corners stoping the welting from going between the cowl and the body.
    warbird1 likes this.
  4. 31Apickup
    31Apickup
    I don’t like the look of the welting, on the last one I used polyurethane sealant.
  5. Almostdone
    Almostdone
    sidevalve8ba likes this.
  6. Model A Gomez
    Model A Gomez
    Done 5 Model A's and used welting on all of them.
    The37Kid and sidevalve8ba like this.
  7. Corn Fed
    Corn Fed
    On the Model A's that get real paint, I've used 3M body seam sealer that can be painted over. That way there are no water leaks. The 1 old paint car I've done had original still in it that I left.
  8. Lloyd's paint & glass
  9. Dino 64
    Dino 64
    from Virginia
    I used narrow welting.
    Just Gary likes this.
  10. The37Kid
    The37Kid
    There are several manufacturers, step up and buy the BEST, it saves a lot of aggravation. The guys on Ford Barn will know the supplier. Bob
