For sale, model A hot rod ch***is only. Body and wheels are NOT For sale. I bought this unfinished project off bonneville racer Terry Coe about 5 years go and have not done anything with it so I am offering up the ch***is. This is a great start to the ultimate banger hot rod. It has lots of great work already done and could be finished easily. It has a fresh rebuilt iron duke with isky cam and flat top pistons. The motor has home made valve cover adaptor and intake/exhaust adaptor to allow you to run early speed equipment with modern power. It’s a Model A Ch***is with dropped and drilled 33 front axle round back spindles juice brakes reversed front spring unsplit 32 wishbones F 100 crossmember with pedals clutch and brake linkage all figured out 39 Ford top shift trans mounted to 40 Ford rear end that has been shortened inbound lever shocks F 100 steering homemade headlight bar tons of neat little tricks a really good start to a killer project I have a few boxes of miscellaneous items that go with the ch***is. I will put rollers in the car for easy transportation. $5,500 located in englewood NJ
