Technical Model a hotrod steering
Discussion in 'Traditional Hot Rods' started by ray henry, Feb 17, 2026.
  1. ray henry
    ray henry
    I'm starting a new build. Stock model a and putting in 8ba v8.
    1. Do I put motor mounts level with frame top?
    2 vega box with cross steer or f1 box with original steering.??
    Ill have custom steering column to fit whatever.
    3. Retaining stock front axel and adding juice brakes.
    Any suggestions on any of the above
  2. dwollam
    dwollam
    I have an F1 going in a '30 sedan with flathead V8 and I used a '53-'55 F100 in my '32 Sedan with 8ba. Gotta cut the mounting flange off both and make or buy the new flange to fit the frame right.
    My Avatar '29 AV8 Sedan has a '40 front axle and steering box and column with cross steer.
    Dave
    Dave Mc likes this.
  3. 29Sleeper
    29Sleeper
    from SoCal
    I heard Randy Gross is in the process of producing a new F1 box for Model As. Even his rebuilds use a 1 piece steering shaft where most are welded. No custom column needed.
  4. brokenspoke
    brokenspoke
    F1 is what I used
  5. lake_harley
    lake_harley
    I used a Vega cross steer setup on my '31 Model A Coupe and I'm very pleased with it. It steers easily and bump steer is very minimal.
    I'm going to send a personal message to you regarding some parts including front and rear brakes a original Vega steering box and other things that you might be interested in considering the direction you're taking your car. Where are you located?
    Best wishes
    Lynn
  6. ydopen
    ydopen
    I used an F1 with a model A flange welded on. If I was going to do it today I would probably use a steel flange. IMG_0510.jpeg
