Technical Model A hydraulic Brake Conversion- Rear
Discussion in 'The Hokey Ass Message Board' started by BenLeBlanc, Jul 26, 2015.
  1. Rotate wheel cylinder forward~ 15* and cut relief in backing plate for perch
    0 vote(s)
    0.0%
  2. Flip wheel 180*, flip brake cylinders upside down, and reverse the mounting side
    2 vote(s)
    100.0%
  1. BenLeBlanc
    BenLeBlanc
    Hey there. I am about to attempt this for myself. Now I have read the following site as well as many posts here on the HAMB.
    RELATED:
    http://www.lainefamily.com/ModelAFiles/ModelABrakeUpgrade.htm
    http://www.jalopyjournal.com/forum/...ting-39-48-hydraulic-brakes-to-your-a.124112/
    Now, I just wish I knew what he used to make the intricate cut seen in this video.
    My set up: (Four posts down from top or so)
    http://www.jalopyjournal.com/forum/threads/1930-ford-coupe-project.954246/page-6
    -I do not have access to a machine shop, and have not found one to do non-business work yet.
    -I do not really like the cutting method as I believe; especially up here in new england, that the open space is just begging for salt, water, and dust.
    -People do not like the full flip as the bleeder is in a location that can be hit by debris.
    What is the best way?
  2. Russ B
    Russ B
    I did the flip method on my A in the early 60's worked fine, bled fine.
  3. BenLeBlanc
    BenLeBlanc
    What did you use to make the crescent cut?
