Model A interior wood removal ?
Discussion in 'The Hokey Ass Message Board' started by Bphotrod, Dec 19, 2007.
  1. Bphotrod
    Bphotrod
    from da U.P.
    Working on teardown so I can do the chop, and cant come up with an easier way to pull the nails out that go through the body into the wood. They are all in great shape unfortunately, I'm thinking grinding of the heads of the nails, any better suggestions?
  2. vintagered13
    vintagered13
    Try indenting the tops with a punch, then using that to drill out the tops of the nails. Kind of like drilling out a pop rivet. Should save the wood more so than risking hitting it with a grinder.
  3. Just Gary
    Just Gary
    Bump.
    Because I'll be doing this in another month or so...
  4. flt-blk
    flt-blk
    from IL
    The nails used are ring shank, they are "ribbed" and will not come out. I think the idea to drill or grind the head off is a good one.
    I re-used a B pillar piece in my Model A because the Oak was still in great shape.
