Fell in love with a new project, 1955 Lincoln and this Jalopy has got to go. Asking $5500 for what you see here. Also included are 4 wide five rims, 28/29 headlight bar with headlights. Fires right up, yard drives, timing and carb dialed in runs like a scalded dog when you jump on it. Can sell without the bed, cowl posts, headlights and rims for $5000 Have videos of it running I can email, better yet come see it in person. The Bad Tires are rollers. Radiator leaks, plan was to get one of those aluminum jobs never got to it. Bed has usual rust, needs rear channel replaced, no floor, tailgate has a bite out of the corner. The Good Chassis Model A Chassis, 34-36 front axle, 32 perch pins, reversed eye springs front and back, 35/36 Wide Five mechanical brakes.New wheel bearing, kings pins, shackles. Motor Rebuilt Banger, 40 over, modern valves, adjustable lifters, aluminum cam gear, touring cam, Burns down draft intake, Holley 94, 12 Volt FSI distributor, NuRex Alternator, balanced and lighten flywheel with V8 clutch. Transmission\Rear Clings Adapter kit, Rebuilt 37 Trans, Model A rear with new bearings and seals. Misc. Electric fuel pump, boat tank in bed
dropping price $4500 Will do $4000 without Bed, seat, cowl posts, fuel tank, electric pump, and extra parts.
