Model A juiced breaks?
Discussion in 'The Hokey Ass Message Board' started by Kcarey, Aug 14, 2012.
  1. Kcarey
    Kcarey
    I have a stock model A ch***is and need to switch the breaks over. My buddie has a f100 frame at his shop, but we are not sure of the year. By the shock mounts it appears to be a 48-52. Does anyone know if i can take the spindles and hardware off and and put it on the A? I read 48 spindles will fit but not sure if these are 48 though. Any help would be great thanks.
  2. First off, they're juice brakes, not "juiced breaks", unless you dropped your juice box and it broke.
    Secondly. a 48-52 is not an F-100
  3. Fenders
    Fenders
  4. Texas Webb
    Texas Webb
    And you"ll have to use all the brake hdwr f1 spindles use a larger inner bearing.I believe kingpins will fit?
  5. john walker
    john walker
    so carl, what's the trick?
  6. brokenspoke
    brokenspoke
    Try reading the tech section on model a brakes
  7. Fenders
    Fenders
  8. Kcarey
    Kcarey
    Thanks, I wasnt sure how to work the sight but i figured it out and found a couple adds in the tech section. Hopefully I can get them switched over, thanks for the help again
  9. P***ing on the Wisdom!
