Technical Model A-M40 Volvo
Discussion in 'The Hokey Ass Message Board' started by skip65, May 16, 2024.
Tags:
  1. A bolt in M40 gearbox with no torque tube modification.
    My friend Nöru and I were discussing the Volvo M40 gearbox and the threads on here, about it, and the difficulty of getting the gearbox to fit into a Model A without changes to the torque tube. Me being a ****er for punishment, said I would have a go at it. Now here in Europe Volvo gearboxes are not hard to find and nor expensive.
    There is a lot of info on here, the H.A.M.B. about what you have to do, and I studied these threads, and my friend dropped a Volvo gearbox off to me to have a play.
    Here’s a short summary of what’s needed
    Model AA truck bellhousing, or aftermarket short bellhousing
    Volvo M40 gearbox
    modify flywheel for Volvo clutch
    Adaptor for Volvo input shaft pilot bearing
    Adaptor model A clutch fork to Volvo throw out bearing
    Shorten Volvo input shaft about 16mm
    Adaptor centring ring Volvo gearbox to Bellhousing
    G-son, barobert, Budget36 and 3 others like this.
  2. Adaptor ring Model AA truck bellhousing to Volvo gearbox
    Flywheel modified for clutch
    barobert and vtx1800 like this.
  3. I pulled to gearbox apart to get the output on to the bench
    This shows the rear bearing support and first gear with synchro
    Output shaft fully dismantled
    barobert likes this.
  4. The output shaft is just too long. After thinking about a few different ways of making this work, modifying the splines on the uni joint etc.
    The shaft is very hard, even with carbide tooling and a high speed head on my mill, cutting splines to match the Ford uni wasn’t going to be fun
    The area in the photo shown as splines and speedo drive is undersize for the Ford uni joint max diameter
    So I got the out Tig out, and carefully, trying to minimise distortion, welded them up
    Setting up to check the welded shaft for straightness
  5. There was a bit of a bend in the shaft, but in the thread area, using a four jaw chuck to compensate for that, I machined the shaft to dimension
    Set the shaft in the mill, and cut the splines to match the Ford uni, this went easier, as the welding had taken a bit of the hardness out of the shaft, I don’t think this will be an issue, but only time will tell
  6. I machined the splines all the way along the shaft, under the bearing area and up to where a spacer/thrust ring goes before the first gear surface
    Uni test fitted on shaft
    barobert, Just Gary and brading like this.
  7. So here’s my dastardly plan
    Had to get the colouring pencils out for this one, doing this on an iPad, don’t have any fancy software, it may look like something Wile E Coyote could come up with
    Adaptor gearbox side, copied dimensions from Volvo but bearing depth adjusted for the narrower bearing, holes drilled for the back of the Volvo gearbox, and a relief hole for the reverse gear shaft. Please excuse the machining marks, trying to do too many things at once
    Shortening the shaft and hole drilled and tapped to accept the original bolt
    Machining the uni down to go under the bearing
    winduptoy, barobert and 40 Olds like this.
    Test on the output shaft
    Adaptor on the gearbox, more work to be done yet
    Finished adaptor, shaft, uni
    winduptoy and SuperKONR like this.
    Details on the adapter, allen head bolts to mount to the gearbox recessed in to clear the uni, holes for the shift rods to come back into the adapter. Holes for the TT clam shell mount up, here I stuffed up, the top hole interferes with the shift rods, I should of rotated the TT clam shell to clear or possibly used a V8 style clam shell, they only have 4 mounting bolts. Another thing I used a V8 uni joint, they are stronger than the original Model A style. I used steel for the rear adapter for strength reasons and I could get good quality steel in that diameter (165mm). Not shown in these photos, but I drilled and tapped a hole for a zirk fitting to grease the uni
    ***embled, it’s a bit tricky to get it together with putting the lay shaft in and the shift shafts, then the rear adapter bearing carrier
    winduptoy, barobert and rmcroadster like this.
    Side by side, a bit of optical illusion with the camera, with the ruler on top, it’s not sloping down, they are the same length. A bracket for the pedal shaft has to be made, and another to mount the handbrake lever
    jet996, winduptoy, barobert and 7 others like this.
  14. 51504bat
    51504bat
    Dimensions for the rear adapter, I made this with a lot of machine a bit, test fit, machine a bit more, so there’s not a lot of exact measurements, I would test fit for clearance, ***emble to see how it went.
    While I was doing this project, I had a skiing accident and ended up getting my hip replaced, which slowed things down, so it won’t be fitted to the car until winter, there’s too many events on now to take the car off the road. It will be going behind a rebuilt G28, so we will see how it holds up. Typical when this was under development, I got sent this
    I guess great minds think alike
  16. MARKDTN
    MARKDTN
    Nice work!
    winduptoy, skip65 and 51504bat like this.
  17. pprather
    pprather
    Great tech thread. Thanks.
  18. tubman
    tubman
    About once a month I am totally amazed at talent, skill, and ingenuity some folks exhibit on this forum.
    This is one of those times.
    winduptoy, skip65, cfmvw and 3 others like this.
  19. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks for posting thought-process, good pics, n dimensions.
    Marcus...
    winduptoy and skip65 like this.
  20. Thank you for the replies, I put a lot of photos, to show as much as possible, and I’m not the best writer. Even though I have been on the spanner’s for more than 35 years, I have learnt so much from the H.A.M.B, and keep learning everyday. The dimensions and drawings are my way of saying thanks
  21. hotrodA
    hotrodA
    Not only can you make the plan, you can bring it to completion with your matching machining skills!
    Great work!
  22. barobert
    barobert
    A really great work Paul
