Model A MECHANICAL brakes?
Discussion in 'The Hokey Ass Message Board' started by striper, May 8, 2013.
  1. striper
    striper
    I have a stock 29A with mechanical brakes. When you apply the brakes they work but as you push a little harder there is a substantial "clunk" that can be heard and felt through the pedal.
    If I had to decribe what I thought was happening I'd say it was as if a shoe was loose and rotating a little with the drum.
    I have the (front) drums off right now and nothing appears obviously out of place or loose. It seems to be coming from the front. I am not familiar with these early brakes so I wondered if any of you might have a clue of something to look for.
    Thanks
    Pete
  2. OLD HEMI
    OLD HEMI
    You should check all the brake rods and clevises, pivots including the shafts in the backing plates. When I did the brakes on my father-in-laws 30 I found the slides that the shoes slide on ( mounted on the backing plates ) were rough and the shoes would not slide.The shoes would hang up so you didn't know which shoe was going to work. I rebuilt th slides with hard surface rod ( used to hard surface loader buckets) dressed the welds down , re***embled the brakes. There was a 100% improvement in the brake operation. Hpoe this will help.
    Lee
    ejgloss likes this.
  3. OLD HEMI
    OLD HEMI
    You should check all the brake rods and clevises, pivots including the shafts in the backing plates. When I did the brakes on my father-in-laws 30 I found the slides that the shoes slide on ( mounted on the backing plates ) were rough and the shoes would not slide.The shoes would hang up so you didn't know which shoe was going to work. I rebuilt the slides with hard surface rod ( used to hard surface loader buckets) dressed the welds down , re***embled the brakes. There was a 100% improvement in the brake operation. Hope this will help.
    Lee
  4. striper
    striper
    Thanks Lee. I was hoping to avoid a full rebuild, but that may be what's needed.
