Hot Rods Model A opinions please
Discussion in 'The Hokey Ass Message Board' started by mickeyc, Oct 27, 2024.
  1. mickeyc
    mickeyc
    Good day fellows. Mick here from the New Orleans area.
    I am in the process of rendering my 31 Model A road ready. I would ask the local A club guys for an opinion. However, once the local fellows found me to being more hotrodder as opposed to
    being a purist they became rather not. So that being what it is I turned to where
    information abounds. I have discovered a broken leaf in the front suspension spring ***embly.
    The third leaf above the main to be specific. I have a similar spring on hand as well. Same number
    of leaves and material width and thickness as the original. The replacement/ repair spring has a reversed eye main leaf. It also has rubber eye bushings, which appear to be new. I am seeking too
    either use the spare spring for pieces to repair the original spring or perhaps use the entire ***embly.
    I am actually making the coupe semi original with the 4 banger and drive train. I am using 19 inch
    original wheels and tires. I am not opposed to a little drop in the front end, much to the chagrin of the local purists. Any suggestions or ideas and opinions would be appreciated. thanks guys.
    dana barlow likes this.
  2. Tim
    Tim
    from KCMO
    Not really sure that you asked a direct question.
    but yeah you can replace just the leaf or swap the whole pack. The reverse eye will drop it about an inch. If you have mechanical brakes I’m not sure if that’s enough drop to start becoming a geometry issue. But it’s something to consider
    05snopro440 and walter like this.
  3. 19Eddy30
    19Eddy30
    from VA
    If reading correct ,
    Not that much work to drop front axle down from crossmember , use c clamps remove threw bolt ,reales leaves ,
    Swap / fix leaf , clamp back witch c clamps , install threw bolt , raise install axle U bolts , trial and error on ride height
    ALLDONE likes this.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    I run with one leaf removed from tbe front spring. Much more comfortable ride. The ride height is affected more by the amount of sag the 95 year old springs have. I put a reverse leaf in but made virtually no difference as the replacement had a higher arch. Whilst you are at it swap some leafs left to right to counter any drivers side sag it may have acquired over the years.
    osage orange, mvee33 and Tim like this.
  5. dwollam
    dwollam
    Personally I would not use the rubber bushings.
    Dave
    jet996 and osage orange like this.
  6. mickeyc
    mickeyc
    Thanks for the input guys. I was kidding about the Mode A purists. They are a good group.
    I have come to realize the people on the hamb are knowledgeable concerning most anything
    vintage vehicle. I have not delt with a spring pack before. I do know the original Model A
    spring used steel bushings in the eyes as well as the perches. The bushing that are now
    in the spring eyes may be some type of somewhat pliable poly or teflon. I am inclined to use them
    if the new shackles I ordered will fit. The is A relatively light. It does have mechanical brakes.
    The question of sag in the pack is another concern. I just today received two books by
    A model A expert. A fellow by the name of Les, (his last name escapes me at the moment) One has a complete break down on how to determine the desirable unloaded
    arc of each spring leaf by measurement. The gentleman also states the each leaf can be re arced
    by clamping in a vice and bending. I see some trial and error work ahead. I am a believer in gathering
    as much understanding as I can before ***aulting various components. I really am impressed with these two
    information publications. Also the swapping leaves end for end to counter drivers side sag is an idea
    I would not have considered. Makes sense to me. Thanks guys
  7. 19Eddy30
    19Eddy30
    from VA
    The bushings on Original perch eyes if like 32
    Where Leather type material,
    Some one with clarify
  8. dwollam
    dwollam
    Model A were steel bushings. Nylon or what ever they are work too but may not be the same size as stock Model A.
    Dave
  9. alchemy
    alchemy
    If you are going to replace just the single leaf from the extra spring, make sure they have a similar arch. Check when you have them completely dis***embled.
  10. ALLDONE
    ALLDONE
    what am I missing here.... the whole spring pack is 120 bucks...???? why would anyone just replace the main.... the main is 90 bucks????????????????????????????????????????
  11. ALLDONE
    ALLDONE
    and his name is Les Andrews
  12. ALLDONE
    ALLDONE
    re read the first post.... just look at the car... would you like it 1'' lower??? or not.... if not go through the work to swap the main.... or just pull the 3rd leaf and replace it.... if you opt for the replacing of the 3rd... don't un hook the shackle's... un hook the u bolts put 2 birg c clamps on the spring pack.... take the center bolt out slowly un screw the clamps ... replace the 3rd and put it back together..
    Just Gary likes this.
  13. mickeyc
    mickeyc
    The shackle bushings are showing excessive wear. I thought the bushings were steel.
    There is no evidence of leather in the suspension system that I can determine.
    Yes Mr. Les Andrews is the author and publisher of the referred to manuals.
    They are most helpful, and a wealth of information. I did look into replacing
    the entire spring ***embly. They are out of stock at the suppliers I contacted.
    Apparently, the springs have been out of stock for a few years according to the
    person at Snyders. I bought this A in California in 2008. I had fully intended
    to make a hot rod out of the little coupe. Now 12 years later I have grown to
    appreciate it for what it is. Being a hotrodder very much, it is difficult not to
    molest the car. Especially since the replacement 4 cylinder banger is literally
    sitting next to a fully ready to rock 1970 LT1 Chevy motor, along with a fresh
    354 Chrysler Hemi. A friend strolled in into my small shop and caught me with a
    tape measure doing some ch***is measurements. Tempting I admit. I am
    not going to suc***b and will finish my sympathetic repair and freshening up.
    Thanks guys.
  14. 19Eddy30
    19Eddy30
    from VA
    For out of Stock / Back order
    Have you tried Direct contact
    In Pa ,
    Or local spring shop to be made
  15. mickeyc
    mickeyc
    I have spoken with a local ch***is shop that has been around for decades.
    They said all they do now is big truck stuff. My inquiry was to trivial to be
    considered. I have all the spring stuff I need to made a repair. Thanks to
    the fellows on the hamb and as well as the excellent manuals from Mr. Les Andrews
    I am thinking I can achieve satisfactory results. Of course I always think that.
    Sometimes good sometimes not so good. I will try anyway. Thank you Sir.
  16. 19Eddy30
    19Eddy30
    from VA
    I was just giving some suggestions,
    I'm sure you should be able to accomplish with what you have described ,trial and error put together take apart,
    Parts do not alway need to be New ,
    Sometimes it makes it easier with new parts but not always the best!
  17. mickeyc
    mickeyc
    Thanks Eddy. I do appreciate and seriously consider all suggestions you and others have graciously
    extended. I was all about the $200+ or so new spring. I could not find any supplier that had this item
    available. A good friend offered up a spring he had in his stash. I really think he saved the day for me.
    Thats when I came to the Hamb for information and encouragement. No place like here.
    osage orange likes this.
