I'm building a 31 coupe and trying to keep the original pedal setup with a dwight bond adapter with a flathead and an S10 trans.All I have is the pedals,no linkage,will this work or do I have to change to the 39/40 pedal setup? Disc up front/drums rear.
I am not familiar with the 48-52 housing but you might check out the adapters available to install the pedals on a '32-'48 transmission. Try Dennis Cling at clingsaftermarket.com, (480) 777-1202 a**** others. Charlie Stephens
Hey Charlie thanks for the website info but his is just for ford transmissions and I'm using a S10 T5. I see lots of posts of people saying how easy it is with different adapters but when it comes to pedals things start to get a little vague.
It will work. You'll need to adapt the pedals with your own design for clutch and brake engagement like this guy did. Here's a link to his thread. http://www.jalopyjournal.com/forum/threads/model-a-frame-almost-finished.928313/ There is a threaded hole for a rod to hold the pedals on the adapter.
hey , now were starting to get to what I'm after! Sure would like to see under that plate to see how he has the brake pedal actuating the master cylinder.Thanks for the help!
