Looking for examples of pedal locations/fabrication used with the t-5 transmission.I used hanging pedals in my last build but now thinking about mounting the master and pedals under the floor,any examples would be great,did a bit of a search and did not find much.....help please.... thanks Brian
A lot of guys use a 39 pedal setup. I used a universal one from Pete & Jake's w/ a hydraulic clutch with a "puller" type slave. Butch
Hey Brian you can use F-1 pedals and cross member piece under there. You will need to move the battery box. But this is a pretty sanitary set-up. I'v got some of the pieces if you need them. Tim
Not under the floor but what about the early 60's pickup master cyl. mounted on the firewall with an Ansen type firewall mounted pedal arrangement. That leaves plenty of room under the floor for exhaust. Frank
His way to do it. http://www.lainefamily.com/ModelAFiles/ModelAT5.htm http://www.lainefamily.com/ModelAFiles/ModelABrakeUpgrade.htm
yea cool stuff guys... any one got pics....my room is limited, with that t-5 down there. I know I can engineer something cool,but need a starting point ?????? thanks brian
