Technical Model A question ......
Discussion in 'Traditional Hot Rods' started by sickiee32, Aug 10, 2020.
  1. My '30 Tudor is chopped 4" body channeled 2.5" I'm 6' and 240 lbs, I fit ok. It has a Y block and the Ford-o-matic trans. This transmission is not too fat, in fact the bell is not any larger than a 3 speed bell. What I did to get the most room inside is stretch the frame 5.5" and mount the motor low so I end up with a flat floor. I know you have a ch***is built already so this may not help much.
    lothiandon1940 and chryslerfan55 like this.
  2. winduptoy
    winduptoy
    Yes, stock seats though the Vicky and the Cabriolet have a 1-1/2" chop from the factory if you start measuring stock windshields on other models . The 30-31's have more leg room than the 28-29's. Two Roadsters are chopped but you take the top off all that low roof goes away so you can straighten back up. I've got one '29 and three 31's.
    I rode in a buddys chopped '30 Roadster and was the most comfortable as he dropped the seat for headroom. He leaves the top on for long drives. It had nylon webbing and foam in place of the seat springs. The webbing was just above bottoming out. I drive the cars a lot, the '29 got 14k miles on it in 2018 and the other cars got miles as well.
    I agree with, I think it was thirty-three and a third, remove the package tray to push the seat back. Go set in a stock one for 8 hours just to see how you feel after you get out. Still takes me awhile to get my land legs back.
    Shutter Speed and chryslerfan55 like this.
  3. rcavaliers
    rcavaliers
    from downey
    I'm 6' tall and I drive a 7" chopped unchanneled sport coupe with a 39 toploader. Its all in the way you set up your seat. Keep in mind if you use an auto ****** it would actually take up more room than a manual.
    Sent from my SM-G960U using The H.A.M.B. mobile app
  4. rcavaliers
    rcavaliers
    from downey
    Here's what it looks like inside with the car being unchanelled. I ran my exhaust along the bottom of the car to help hide the stock model A frame. 20180916_111018.jpeg 20180916_110851.jpeg 20180916_110619.jpeg 20180916_110511.jpeg 20180713_233023.jpeg 20170611_125206.jpeg
  5. sloppy jalopies
    sloppy jalopies
    351 is wider than a 302, but memory says they are the same length...
    Personally I would reverse the '30 firewall as I like the look of the beadwork it retains...
    reversing buys 3.5" to 4.5" of engine bay... depends where you cut it...
    AOD is a girthy fellow 14" wide... c4 is smaller than a c6... FMX is wide and cast iron, heavy...
    early c4s used the 157 tooth flexplate [smaller bell]…
    last resort put in a column shifter... my $0.01.
  6. Blues4U
    Blues4U
    from So Cal
    I have nothing to add, just wish you luck. Let us know how it turns out.
    Nicholas Coe and -Brent- like this.
  7. Mechman_22
    Mechman_22
    from Nc
    Im 6'4 285lbs and im building a 30 Tudor no chop but channeled. it originally had a 351w/t5 and had room with flipping fire wall. I have switch from the 351/t5 to a nail head/Muncie combo but here are some pics I snagged while I had the 351 in the frame. have more pics on my thread as well hope it helps some
  8. wheeldog57
    wheeldog57
    Sickiie,
    I used a second row Caravan seat in my unchannelled 29 roadster. Fabbed up very short brackets to bolt to the floor, this allowed me to move the seat under the tulip panel. I am 6'5" 225lbs.
    A friend has a 30-31 coupe that is chopped and channeled, has small bucket seats mounted low.
    I sat in it but. . . . My head was hitting the top, my right knee was at same height as the dashboard, and I could not get the door closed because my left leg would not go under the steering wheel. Auto or not, I could not drive that car.
  9. pitman
    pitman
    It's all about the real estate, in the lower left cowl-pedal region.
    If you can set up your driver seat, for Comfortable throttle location, you'll have it. An automatic, w/no clutch usually offered more room.
  10. sickiee32
    sickiee32
    rcavaliers and chryslerfan55 like this.
  11. sickiee32
    sickiee32
    did that t5 handle the 351w ok ??
  12. Mechman_22
    Mechman_22
    from Nc
    I put it in and then found the nail head and opted to pull in favor of the nail head. Im still building it so I cant comment ,but I would think a world cl*** t5 could hold up to a stock 351w.
  13. -Brent-
    -Brent-
    Your seated position is a little tougher channeled with 3 pedals. Also, it does get a cramped at the firewall where your feet/pedals need to be.
    If you do a T5, swap the tail section to the one that moves the shifter position forward.
    My A is not channeled and I'm 6'2". My coupe has a 4" chop and mustang seats with sliders, I pulled the roof wood so I have head space when I'm bouncing around. Otherwise, I think I'd clear just fine.
    I purposely worked things so I had a flat floor.
    No package tray and my firewall is reversed. I ran hanging pedals to maximize space.
    coupe33, akoutlaw, Almostdone and 4 others like this.
  14. I went with no chop no channel in my '29 Tudor Sedan. I'm 6'1" 240# and I was uncomfortable as hell, not to mention it was difficult getting in and out... StrayKat 500 2018 (2).jpg
    I helped build my buddy's Coupe which was chopped and channeled, I could barely get in and couldn't see very well! Chopped and channeled looks cool but not the least bit comfortable...
  15. fiftyv8
    fiftyv8
    from CO & WA
    Good head clearance, does not always equal good vision.
    The header panel plus distance from seat to windshield usually decides that and it does not matter where the pedals are...
    Shutter Speed and fastcar1953 like this.
  16. Dino 64
    Dino 64
    from Virginia
    For what it’s worth, I’m running a T-5 behind a SBC. There is room for the pedals as the T-5 is much smaller than a AOD. A C-4 would be much smaller for an automatic choice. A couple of pics from when I was building my floor. Forget the channel if you with a T-5 87F8BAE4-9F9D-41A2-849D-42752326D2A7.jpeg 87F8BAE4-9F9D-41A2-849D-42752326D2A7.jpeg
  17. scrap metal 48
    scrap metal 48
    Heavy chop(6 1/2"), no channel, model A frame... **clic pic** 100_3581.JPG 100_3584.JPG 100_3585.JPG
  18. goldmountain
    goldmountain
    I'm 5'4" tall and it is still a tight fit.
  19. PotvinV8
    PotvinV8
    I'm 5'10" and in a stock Model A coupe with a T5, it's close quarters. But the T5 doesn't make it tight, they're just small cars to begin with. I built a channeled '32 Roadster pickup with a Hemi and T5 and driving that required lots of footwork, wasn't fun. Chopped is one thing as you can always hunch over or crouch slightly as you're driving. In a channeled car, put the pedals up even with the bottom of your seat and try to bend your legs enough to fit and still clear the steering wheel and shifter it's another story.
    After the RPU, I will never build another channeled car.
    fastcar1953 and Shutter Speed like this.
  20. kaspar
    kaspar
    My previous car was a model A, chopped around 6", channeled around 5", Cadillac 390 and Muncie gearbox. I'm 5'8" and it was CRAMPED in there. If you're tall, don't get too crazy with the angle grinder.
    I had to relocate the shifter to the center and back, otherwise it would hit the steering wheel (9 3/4"). With a T5 you won't have that problem (?). I had modified MG midget seats to get as close to the floor as possible.
  21. fiftyv8
    fiftyv8
    from CO & WA
    Auto ******'s are generally larger in size, yet require 1 less pedal so no loss there.
  22. Illustrious Hector
    Illustrious Hector
    Wish I would have chopped, instead of channeled mine
    fiftyv8 likes this.
  23. brianf31
    brianf31
    Check out my A coupe build. 4" chop, 4" channel on 4" tall rails with a 4" recessed 351C and toploader. Pedals are tight but its definitely doable. My 6' tall kid drives it no problem.
    I wouldnt dream of putting an auto in it.
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    -Brent- and Shutter Speed like this.
  24. brianf31
    brianf31
    Brent is right: move the shifter forward. My toploader shifter was tight against a Caravan bench seat. I gained shifter and leg room by using small fibergl*** airplane bucket seats.
    Use a Mustang T5 clutch cable (Brizio modified is what I use) or a hydraulic clutch. You won't have room for a Z Bar.
  25. Kiwi 4d
    Kiwi 4d
    To me the real question is as far as running 3 pedals , what size are your feet? I am sure you don’t want to wear cobra drivers shoes.
  26. sickiee32
    sickiee32
    size 12 ...6’3 ft
  27. sickiee32
    sickiee32
    Pics ???
  28. brianf31
    brianf31
    See the link in my sig line.
  29. chevycarcollector
    chevycarcollector
    from PR
    1930 with 3.5" chop and 4" channeled on top of a Z'ed frame from riley automotive. Ford 429 engine with 4 speed toploader with a reversed firewall. It is tight (I'm 5-8"). Yeah its hard to see traffic lights, getting in/out, 2 inch roof clearance, blah blah blah... but can't beat the cool factor and I drive it around. I chose manual ****** because with that 4 inch channel it gave me about 2" incremental on each side of the trans tunnel. Had to use hydraulic TOB as there is no space for anything but the pedals under the floor. Screenshot_20200812-215641_WD%20Photos.jpeg Screenshot_20200812-215650_WD%20Photos.jpeg Screenshot_20200812-215632_WD%20Photos.jpeg
    Jet96 and sickiee32 like this.
  30. -Brent-
    -Brent-
    The nice thing w/a t5 is the shifter is centered. With my Muncie, I'm going to need to modify the stick toward the center to clear my leg and give me some room.
    brianf31 likes this.
