Model A questions
Discussion in 'The Hokey Ass Message Board' started by ThirtyFordor, Jun 18, 2013.
  1. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    Building a 1930 model a Ford how do I go about building a floor without using a subframe? Do I just use wood there has to be a way all the hot rod guys build the model a's
  2. dynaflash
    dynaflash
    from South
    Well the way that everyone has answered the barn find car was thing leads me to believe that this will get some funny answers as well. Let's see
  3. plate steel, 11 GA or buy subframe sections from a donor, aftermarket supplier, etc..
  4. Fenders
    Fenders
    On my first rod some years ago I just used plywood.....
  5. Mr48chev
    There are a bunch of Model A build threads on here that show several different ways to do the floors. I've got a 31 Victoria that the floor is 75% wood on and it's going to end up with an all or almost all steel floor by the time I'm done.
  6. is it a `30 four door? i believe that the sub-rails in them are wood from the factory and usually all rotted away. the doors are wood framed too , i'd try to replace it all with steel
    maybe you could post some pictures so we can see what you have
  7. Rattlesnake
    Rattlesnake
    Have you considered formica? Lotta cool designs in it and it goes real good with glastron boat seat covers. Just kiddin thirtyfordor. I'd go back with steel subframe and steel panels. Then no more termite worries plus the steel is alot lighter and stiffer.
  8. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    So just bolt the body to the ply wood and then bolt the plywood to the frame??
  9. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    Does anyone have dimensions for the subframe in a 1930 model a fordor?
  10. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    Need any help I can get
  11. Fenders
    Fenders
    In my old rod shown above, I added sort of a K frame to the main frame, made from 1x1 steel tube, welded to the main frame.... Then I bolted the body to the main frame, adding body mount tabs to the frame where necessary. Finally I put the wood floor in, as I recall 3/4 plywood.
  12. charlesincharge09
    charlesincharge09
    from Wisconsin
    where in wisconsin are you? building a subrame from 1"x1" steel will cost you no more than $60 and some man hours, easy to do, and it will be done right
  13. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    That's a good idea...do u happen to have any pictures at all?
    @charles I'm located in beloit,wi basically right on the border of wi and il.
  14. charlesincharge09
    charlesincharge09
    from Wisconsin
    Too bad your not closer, here is a picture of how i did mine [​IMG]
  15. gasserjohn
    gasserjohn
    modelA frame...replacement panels fit great as i have a square frame
  16. olskoolrodder
    olskoolrodder
    I built a sub frame then skinned it in sheet metal after running it thru my bead roller. pics on my build thread. I was mating to a duece frame though, so my floor was not flat. same concept though...
  17. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    Do u have any measurements of how long or how wide?
  18. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    What did any of u guys do for the wood in the doors?
  19. smitty29
    smitty29
    from Illinois
    What are you going to use for sub rails, I just picked up a 30 Vicky and was thinking about using some sub rails from a coupe or sedan. Thoughts?
