Model A rear brakes...Can U F1 them?
Discussion in 'The Hokey Ass Message Board' started by Skibo, Oct 2, 2005.
  1. Skibo
    Skibo
    from FL
    Can rear model A brakes be updated to the bendix type?
    I think the front F1 backing plates would bolt up to the rear, and if a front F1 drum was used, would you then just have to switch out to the rear hub?
    Skibo
  2. DualQuad55
    DualQuad55
    from NH
    I think you also need spacers foe the backing plate center hole and the bearings. They are available from speedway and some model A guys.
  3. Skibo
    Skibo
    from FL
    Oh yeah, I forgot about that!
    Thanks,
    Skibo
  4. Skibo
    Skibo
    from FL
    Or what do most of the Hambers run on the rear? All of the Tech articles I find in the searches only mention the front brakes...
    Skibo
  5. nobux
    nobux
    I think it would be near impossible to run F-1 front hubs on a model A rear axle. The model A drums are a tapered keyway design that you would have to replicate on the F-1 hubs. Not doable IMHO. F-2 rear backing plates are an option, but I'm not sure if the later (40-48) drums fit on the model A axle. Sorry I don't have any fast answers.
    Karl
  6. Skibo
    Skibo
    from FL
    No, I think the rear hub from the model A axle or whatnot would have to be used, but it seems do able, just surprised nobody has done this?
    Skibo
  7. Skibo
    Skibo
    from FL
    Bttt
    Skibo
  8. Bruce Lancaster
    Bruce Lancaster
    Front F1 plates should bolt on--no adapter needed in back. From there on, it's a U-Fab jigsaw with no answer in advance. Here's the menu: 1928-48 rear hubs can be fitted on there, so the $64 dollar question is whether one of the several possible hubs with its original drum removed is at the right distance from the backing plate so that a suitably machined F1 drun can be affixed to its front or back surface and wind up in the right place. I think there's quite a decent chance...
