Technical Model A Rear Fender Mounting
Discussion in 'The Hokey Ass Message Board' started by D-Ozzie, Oct 5, 2023.
  1. D-Ozzie
    D-Ozzie
    Okay, I am sure this is a really dumb question with an obvious answer, but I have been searching online and have now spent $200+ on books to try to find some sort of "***embly manual" type information and have been entirely unsuccessful.
    How do the rear fenders for a Model A roadster (1930 in my case) attach to the body? I have a Brookville body and original fenders. The fenders have holes along the body-side flange, which lead me to believe there should be bolts or studs through the quarter panel. I see that the parts suppliers (CW Moss, Mike's Affordable, etc.) carry "rear fender mount studs" that are supposed to "get welded or brazed to the body" (4 per fender) - which seems to be my obvious answer - but I haven't been able to confirm this is correct or find an example of what this looks like. I am not trying for originality, but I am wondering what is "correct". If I can't find an answer I will just drill some holes and bolt them on.
    Stogy likes this.
  2. Phil P
    Phil P
    Looking at my model A repair book (published 1931) the removal description makes it sound like there are studs in the body. Unless you're going for originality, nuts and bolts should be fine.
    Phil
    Stogy likes this.
  3. 31Apickup
    31Apickup
    There were originally studs welded to the body. As Phil P states you can just use bolts and nuts.
    Stogy likes this.
  4. lake_harley
    lake_harley
    My coupe has large flanged bolts from the inside out. You can probably search any number of model A repo parts suppliers for the correct type bolts.
    Lynn
    Stogy likes this.
  5. Los_Control
    Los_Control
    from TX
    Just a idea for you, the fenders on my truck are bolted on, the heads are inside the bed and exposed.
    No idea if yours will be exposed?
    They used what are called elevator bolts. You can see the advantage of using them if yours will be
    exposed.
    Just a random photo from Amazon ... just search elevator bolt for yours.
    Stogy likes this.
  6. D-Ozzie
    D-Ozzie
    Thanks for all of the great responses. This confirms what I was thinking, which was that I was overthinking it. Nuts and bolts, it is!
    Stogy likes this.
  7. tomcat11
    tomcat11
