Hot Rods Model A rear spring help..
Discussion in 'The Hokey Ass Message Board' started by hd1084, Nov 19, 2022.
  1. hd1084
    hd1084
    I'm going to remove the painted clamps tomorrow and see what that does. And then will remove it and take apart and do the mods as mentioned above and see what that brings. I know it will never ride like a new car but it sure has to get better than it currently is. No rear spring in the spring what so ever...
    osage orange and Tim like this.
  2. PotvinV8
    PotvinV8
    You can get these buggy spring cars to ride pretty nice, it just takes a bit of work to dial everything in. The spring you have is fairly easy to work with as it doesn't take much to get on and off. ***embling a stock Model A spring is a major PITA, especially the fourth or fifth time as you remove leaves to dial in the ride! Ask me how I know. Good luck, it will be well worth it if you follow all the advice given.
    hd1084 likes this.
  3. hd1084
    hd1084
    I'm removing the spring ***y. tomorrow. Borrowed a spring spreader from a friend and plan on dialing in the spring to make it "SPRING" !! Thanks everyone for your tech help.....
    Papas32, warbird1 and Tim like this.
  4. twenty8
    twenty8
    I'm thinking that if you are getting no movement at all, it will not be the spring being too stiff that is the problem.
  5. X38
    X38
    Well, once he gets it on the floor and jumps on it we'll know.:)
    Unless of course, the leaves are welded together.:eek:
    100% rigid does sound weird. (there's a joke there, but I'll leave it alone.)
    Budget36 likes this.
  6. brading
    brading
    I have two questions not having much knowledge on leaf springs.
    1 How do you dial in a leaf spring.
    2 I have seen before that people have said about removing a leaf to soften the ride. Have not seen any mention of that this time is there a reason why.
    hd1084 likes this.
  7. alchemy
    alchemy
    You dial in a leaf spring by adding or removing leaves, switching some for heavier or lighter, grinding the edges to prevent gouging, or actually bending a new arch into it. We haven’t suggested removing leaves in this situation because only five leaves for a rear spring is already sounding rather light.
    brading likes this.
  8. brading
    brading
    Thanks for your explanation alchemy
  9. hd1084
    hd1084
    The 5 leaves in this spring are 1/4 " thick, unlike the typical model a spring. I have the spring out and apart and I'm removing the first ply above the main and another ply but adding a thinner one from a model a spring. Adding a 1" spacer on top to keep the ride height. Cleaning up the leaves and grinding the edges and putting back together. I will let yao all know how things work out. Thanks for all your help.
    Tim and jimpopper like this.
  10. twenty8
    twenty8
    While you have it's **** in the air with the spring out it might be a good idea to check that the rear end has a full range of movement. Make sure nothing is binding or fouling.
    dana barlow and Hellbentrodder like this.
  11. Did you need the spring spreader?
    That spring needs to be mounted with preload tension, lots of it too.
  12. Marty Strode
    Marty Strode
    A 40 front spring is 2" wide verses rear springs from 28 to 48 are 2-1/4"
  13. hd1084
    hd1084
    Just put the spring back together today. Installing back into car tomorrow. Will let you know. I think was a combination of too stiff of spring stack, paint binding, and spring ply not sliding.
    Tim and kadillackid like this.
  14. hd1084
    hd1084
    All back together. Much better now. Actually have spring action in the spring. Went for a little test drive and much better !! Thanks everyone for your input
    panhead_pete, Tim and High test 63 like this.
  15. alchemy
    alchemy
    So, tell us what you did to it.
    Happydaze likes this.
  16. hd1084
    hd1084
    I removed 2 of the spring ply's and put a thinner ply from a car spring. Removed all the paint. Added a 1" spacer on top. Ground the ply ends to put a bevel on them. Also put some grease between the plys.
    Tim likes this.
  17. alchemy
    alchemy
    Remove the clamps?
  18. hd1084
    hd1084
    Yes forgot that !!
  19. jimpopper
    jimpopper
    Glad you are dialing that in. That’s an unusual spring for that application but you’re on top of it now.
    hd1084 likes this.
  20. Tim
    Tim
    from KCMO
    Awesome glad you got it sorted :)
    hd1084 likes this.
