Technical Model A rear spring questions (updated with final pic)
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Feb 22, 2019.
  1. Given your spring perches are 46.5 inches you will require a narrow spring
    spring distance eye to eye will measure 41.5 inches
    jimgoetz and sidevalve8ba like this.
  2. Chappy444
    Chappy444
    Update, spring replaced and figured I would replace the shocks as the existing ones are of unknown condition (monroe 31000's)
    Here is what I have now.
    Rear suspension measurements between shock mounting centers.
    Measurements taken without shocks installed
    fully compressed 12" (ratchet strapped diff to crossmember)
    Fully extended 15.5" (frame on jack stands and lowered rear untill it was hanging.
    This is with the axle level
    From what I can gather I need a shock that has a compressed length less than 12" and an extended length greater than 15.5"
    I have found a few options (mostly pickup trucks applications) and I am concerned they will be to "stiff"
    The ones that were on it were Monroe 31000 12" x 19.5"
    One option is the Monroe 32207 11.25" to 17.88" Stock equip on ford F100... seems like it might be overkill on an AV8
    Another options is the So-Cal speed shocks 9.25" x 14.25"... maybe rebound and damping more suited to a hot rod.
    Thoughts anyone?
    Thanks.
    Chappy
  3. Happydaze
    Happydaze
    My experience of the SoCal shocks wasn't great. They changed a stock '32 roadster (fenderless) from a nicely sprung car to being uncomfortably hard. They're probably better suited to a much heavier car. I have some Bilsteins on a project '32 and they seem to be good and I've not heard anything but good things about them, but they're quite costly.
    Chris
  4. cobra5laddict
    cobra5laddict
    from denver
    Chappy,
    You mentioned that it’s back together. How Did the end result come out!?
  5. Chappy444
    Chappy444
    When I got the old spring out it was clear that it was junk... really wore out. It was a 10 leaf pack and I could sit on it and get it to spread 4-6"
    I got a posie narrow spring and fixed the shackle angle
    I also gained some clearance on the on the spring to hairpin mount.
    I was not able to bounce the car hard enough to get that spring to bottom out.
    So now... I just want to dampen the bounce. The shocks that were on it were shot... real easy to compress and took forever to extend. I believe that the 12" compressed length of the 31000 got bottomed out.
    Now I just need to find a shock that has 5/8" eyes on each end and meets the length requirements and isnt to "stiff"
    I used the monroe shock chart that is floating around on here
    I found the 32207's on rock auto for $17 each...I may just get a set and try them and see what happens. At least to find a starting point to work from.
    Chappy
    catdad49, X-cpe, brEad and 1 other person like this.
  6. any updates Chappy?
  7. Andy
    Andy
    I used VW beetle shocks on my 32 and liked them. Soft enough for a light car and long enough to get good travel.
  8. Chappy444
    Chappy444
    I did some research on some shock lengths, working distances, compression and rebound rates, made some more measurements and ordered a set of Bilstein 5125 Series Shock Absorbers Part 33-187112. Just got them on this past weekend and took it for a short ride between ****py weather events. Its a huge improvement over what it was. I still need to redo the whole rear suspension but I have a feeling starting that project may turn into a whole new ch***is project... so, this will keep me driving until then.
    I am still fighting my brake pedal that gets harder the longer I drive issue. The things I have tried so far have not fixed it. I have a thread on that somewhere, I may have to revive it.
    Thanks again for all of the help, suggestions, and information.
    Chappy
  9. pprather
    pprather
    Shock looks like a good choice, if it is soft enough.
    Phil
  10. Chappy444
    Chappy444
    I think it is close. compression is 203 pound-force, and rebound is 524 pound-force
    Chappy
  11. jimgoetz
    jimgoetz
    That's what I'm running on my 27 on 32 frame roadster.
  12. simplestone
    simplestone
    Just curious if you could provide a picture of the new rear spring setup? Thx
  13. cobra5laddict
    cobra5laddict
    from denver
    Hydraulic shocks on light cars are the way to go. Most cars used them up to the 80's. After that the shock industry went to gas charge shocks. I looked and found some straight hydraulic shocks but they were more expensive than i wanted to experiment with. Sachs was one brand i found on RockAuto. I did find through my research that KYB excel-G series was the closest dampening to Hydraulic. I found that the Excel-G had about 40% of the "expanding pressures" of Gas adjust series. I've yet to get them on the car to test but right out of the box they do take substantially less effort to collapse for installation. The expanding force of a gas shock can be upwards of 75lbs of pressure. In my opinion that would have pretty adverse effect on the ride of a light car like a roadster or any A.
    AHotRod likes this.
  14. larry ellingsen
    larry ellingsen
    Be carful unloading that spring.
  15. Chappy444
    Chappy444
    As requested, pic of the current configuration. Not perfect, but good enough to get me through to the rebuild.
    Chappy
    Fordors, alanp561 and F&J like this.
  16. cobra5laddict
    cobra5laddict
    from denver
    Looks much better Chappy!
  17. simplestone
    simplestone
    Thanks for the picture - yes, that looks much better! And hopefully the ride is improved as well. lol
  18. sidevalve8ba
    sidevalve8ba
    Did it change your ride height much?
  19. Chappy444
    Chappy444
    Maybe a half inch or an inch measured from the tire to fender. Nothing really noticeable.
    Chappy
  20. alanp561
    alanp561
    If the body went up, get yourself a fat girl to ride with you. If it went down, look for a skinny gal. They come in all weights so just keep changing until you find one that fits;)
  21. X-cpe
    X-cpe
    Looks good, functions within your range of acceptability, no car in a million pieces, stayed within budget. Ya done good.
    alanp561 and Fordors like this.
